Question about Proview PA-32JK1A 32 in. LCD Television
Proview rx 326 manual
I got rid of dish.....how do i get local network channels. All i have is a blue screen.
  • 8 Answers
SOURCE: proview rx 326 model 3200 tv sound but no picture
If the sound is working, I doubt the power supply is at fault. You can check with a simple voltmeter - red is positive, black negative - there should be 24VDC. There is an on-board regulator to drop the voltage for the CPU, etc, . THere is a green LED on the main board, so even if you don't have a Voltmeter, there is a visual indication that the power supply is somewhat functional.
I found a poor connection from the 24V power supply over to the inverter boards. I re-crimped the IDC connectors to the 24V supply and all was happy-town.
Posted on Jun 05, 2008
redhead7377
  • 51 Answers
SOURCE: Proview 3200 RX-326 LCD TV loses BLUE
Digital brd has a heat related problem..If you did not get a extended warranty then it could be cheaper to just replace the TV...
Posted on Sep 09, 2008
SOURCE: no picture but there is sound
This may be the problem click on your remote source button and see what is checked on the blue sceen that pops up...it may be on the wrong setting... I hope this helps, Ken, Attica, NY
Posted on Jan 28, 2009
  • 17 Answers
SOURCE: turns off and on
If it happens at a certain time every day, make sure you do not have the sleep and wake timers on.
Posted on Mar 08, 2009
SOURCE: digital programming
The RX-326 does not have a digital tuner, only an analog.
Posted on Feb 28, 2010
My proview rx326
It should have inputs for analog AND digital.
http://thebooksout.com/downloads/proview-rx-326-user-manual.pdf
This site seems to have it, but might be a charge.
Sep 26, 2017 | Proview Televison & Video
How to fix a proview 3200 HD TV with no sound?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2014 | Proview Televison & Video
My Proview RX-326 lcd tv Has sound & picture but Picture mix colers brite
There is some incompatibility issue. Did you check the format is set correctly for PAL/SECAM etc.?
Jul 28, 2012 | Proview PA-32JK1A 32 in. LCD Television
Dish network. Blue screen. Aucun signal. How do I get rid of this and get signal back??
Hey there! This issue is usually caused by the tv being on the incorrect channel. Depending on what tv you are at, here are some steps to try. At tv2, the tv will need to be on 60 or 73. At tv1, the channel is 3 or 4, and may need to be on an input. Usually video1 or 2, etc... If this does not work, try to unplug the receiver from the power source for about 10 seconds. Hope this helps!
Becki Barned
DISH Network Customer Service
Jan 13, 2011 | DISH Network 625 Duo DVR Receiver...
Does the proview rx-326 have the digital box
Yes,it have a Digital Tuner inside.It can get free air signal tv.No,need for a converter box like a Analog CRT tvs.
Apr 07, 2010 | Proview PA-32JK1A 32 in. LCD Television
Digital programming
Aug 17, 2009 | Televison & Video
Turns off and on
Mar 08, 2009 | Proview PA-32JK1A 32 in. LCD Television
No picture but there is sound
Nov 24, 2008 | Proview PA-32JK1A 32 in. LCD Television
Aug 28, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview PA-32JK1A 32 in. LCD Television Logo
747 people viewed this question
Top Proview Televison & Video Experts
Tony
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
