Question about HP Compaq Presario V2000 Notebook
I want to install xp on existing vista,also wanted to remove vista on hp dv2000 labtop
Existing vista works good in safe mode, but normal it will boot, after that it is hanging,
  • 128 Answers
Try this > instead of safe mode, choose "last known good configuration". if still no success >>
enter windows in safe mode and restore your system to an earlier date before you encountered this problem
hope this helps
Posted on Nov 07, 2008
    Genius:
  • 1,124 Answers
If Vista it is working well on Safe Mode, you have to check it out what is going wrong there instead of downgrade the system to XP.
Remember: Which was the last program that you've installed?
When was the last time that the system started normally?
You can try uninstalling the last programs
Also clean the computer and be sure that your pc is not virus or spyware infected.
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
My labtop came to a boot up screen that has the options: safe mode, safe mode with networking, safe mode with command prompt, last known good configuration, and start windows normally. i have windows xp....
Hello xderekhx716, to choose the [least] likely {Mode} in order not to "Lose any Data," you want to choose; "Start Windows in Safe Mode." If an incident 'occur' before this 'window' [Popped-Up], then you want to "Start the Computer in {Safe Mode}. This 'way if you have been "Infected by a 'Virus' or any of the Computers Configurations have been 'changed,' or "Windows Shut Down 'Unexpectedly' than Safe Mode is the 'choice,' because the; least amount" of Operating Systems, applications will be deployed at "Startup," ie. Drivers, Programs... This will 'protect' the System' from further 'damage', if there was any? You will have the opportunity to analyze the situation safely. Next, if the Computer is having 'problems' starting, or the "Operating System is not 'responding' or there is "no change, than a "message" will identify the 'still' remaining problem; "Starting Normally." Then you want to 'choose,' start Windows at the "Last Known Good Configuration" also known as "System Restore." Finally, if this was just a "simple "Shut-down?" Than, "Starting Windows Normally" is OK! Follow all the instructions "carefully" in any of the "Modes" you may need to [Choose]. I hope this information is helpful? Thanks for using FixYa, paul7of9"
Feb 08, 2011 | ASUS Eee 4G Notebook
Help my hp dv2000 just keeps restarting??
As the computer is working in safe mode, it is clear that operating system files are corrupt.
Perform a repair installation, if it is Windows XP.
For Vista or Windows 7, you can perform system restore from recovery console. To launch recovery console, insert the disc- restart the computer and boot into the disc. Choose repair in the options tab, then choose system restore from the list.
Regards,
Nags
Jan 27, 2010 | HP Computers & Internet
LAPTOP IS ON SAFE MODE AND I DO NOT KNOW HOW TO GET IT OFF SAFE M
when switching on your laptop please tap F8 key continuously and it should take you to the boot options
Sep 10, 2009 | HP Pavilion dv9000z Notebook
External monitor looks like the computer is in the safe mode
If XP:
Start->Control Panel->Display->Settings tab->Screen resolution->move marker to "more".
If Vista:
Start->Personalize->Display Settings->Resolution->move marker to "high".
Mar 12, 2009 | HP Pavilion dv4000 Notebook
Password
Hi let me which operating system you are using. if its xp only thing you can try is try logging to safe mode. then go to control panel and you can see your username and you can change the password there.
If its vista you can go to advanced boot options by pressing F8 during system setup or when u see the dell logo. select repair your computer, try login with your previous user name and let me know otherwise we can do other steps if its vista. if its xp and then trying the safe mode does not work then you will have to reinstall windows.
thank you
rakesh
Expert in Laptops.
Jan 05, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Safe mode
Hi there, Try tapping F8 on boot to access the boot menu select "start windows normal". if it will not let you boot in to safemode with cmd promt and run "chkdsk /f" to check for bad sectors and repair othere HD issues. Also try "Last known Configuration" as a last ditch effort before moving on to System restore. IF system restore options fail to work let me know and we can do a system restore and restore your system to an earlier time through the cmd prompt. Good luck and i hope this helps
Dec 07, 2008 | HP Pavilion dv2000t Notebook
How to install Widnows xp on HP Pavilion dv2000
Please help me, I bought a HP Pavillion dv2000 Laptop which came with a built-in Windows Vista. Thats cool, but the problem arises when I try to install windows XP. After inserting the Windows XP SP2 CD and after primary driver loading it is unable to detect my harddisk
May 07, 2008 | Computers & Internet
HP Pavilion DV2000
Did you try to do a F8 or F12 and safe mode start, or you can also start from last known good configuration too. Try that out and I hope it gets you up and running,
If you need anymore help just write back here and we will see what we can do. thank you
Feb 07, 2008 | Computers & Internet
Mcafee for xp installed on pc with vista
Do a safe mode start up and remove the antivirus that should get you up and going, also check in your properties and make sure your settings for going to sleep or hibernation are off, Safe mode should get you going also you can do a system restore to the day before all this happend. McAfee for xp will not work with vista. if you want a good free antivirus try Avast dot com. I sure hope you get it up and going if not let me know. Thank you
Jan 01, 2008 | Acer Aspire 5610-4648 Notebook
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
