Turntable i have a stanton t.50x turntable and i'm getting a low volume out of it do i need a phono preamp to mak it sound better?
  • 1,512 Answers
Hi
Yup you sure do. A phono preamp also has RIAA equilisation, that reduces the treble and boosts the bass. You need this because all LP vinyl is recorded that way, and sounds terrible withpout it.
Most amps these days do not have a phono preamp. For a relatively cheap fix for the problem, you could pick up a preamp from here. Another way is to get a DJ mixer, or pick up a cheap amp of ebay, or hit the second hand/pawn shops for something to do the job for you. Happy to answer any questions you may have about it. Cheers
regards
robotek
Posted on Nov 08, 2008
I have a Stanton T60, but I connect to my Bose, but my bose has no phono input, tried aux but low volume... Do I need to buy a preamp?
You don't need a PRE-amp but you do need an amplifier. The auxiliary plug on the Bose is only for iPhones etc which have a margin of their own amplification which your turntable has none. The phono plugs are for the turntable to supply a low power signal to the amplifier to boost it to be audible at volume.
Oct 06, 2015 | Stanton Audio Players & Recorders
Str k885
Your receiver probably has no Phono input. You cannot plug the turntable into a CD input, for example. You will need an external preamp to use a turntable with this receiver.
Apr 19, 2014 | Sony Audio Players & Recorders
How can i use my laptop with the stanton t60 turntables?
Plug the turntable into a phono preamp and plug the preamp into your computer.
Jan 22, 2013 | Stanton T.60 Turntable
The sound is really low if i press the aux tape cd phono or vcr the sound is there but really low
Instructions:
Evaluate your current receiver. Take a look at the back-panel connections to make sure you don't have a phono input. In most cases, the phono input will be clearly marked. If the connections are not marked, look for a set of RCA-style inputs with a grounding screw next to them; this is a phono input. If there isn't a phono input on your receiver, see if you have an open set of RCA inputs. If they are all occupied by other equipment, you can disconnect one piece of equipment, buy an A/V switcher or get a new receiver--preferably one with a phono input.
2 Purchase a phono preamp. The voltage output of a turntable is much lower than those of other peripheral devices, including CD players, tape decks and game systems. Although the inputs look the same, connecting a turntable to a standard RCA audio input will result in very faint sound output, if you hear anything at all. The output of your turntable must be amplified to a level of about 150 millivolts (mVs) before it reaches the receiver, so a turntable "pre-amplifier" or phono preamp is necessary.
3. Purchase patch cables. You'll need a set to run from the preamp to your receiver. Measure how long your cables need to be, and purchase accordingly. Resist the temptation to "go cheap," because better-quality cables will provide better sound.
4. Connect the preamp into the system. First plug the preamp into an AC power outlet. Most models have a small AC-to-DC adapter built into the plug. Then connect the cables from the turntable to the preamp, and connect your new patch cables from the preamp to the receiver.
5. Adjust the gain of the phono preamp. Most models have a gain control for fine-tuning. Follow the instructions provided by the manufacturer and adjust your system accordingly.
F150 Parts.
May 27, 2012 | Audio Players & Recorders
Purchased stanton T.52 Turntable. hooked it up to stereo but volume is very very low. cannot find line / phono switch if there is one on this model.
The only output from the turntable is the low-level signal from the cartridge. Most likely, the receiver you've hooked it to doesn't have a phono input. Many receivers today don't come with one, and if you connect the turntable to a line-level input you get either very low volume or none at all, depending on the cartridge. What you'll need is a turntable preamp to boost the output to line level so the receiver will work properly. Radio Shack still carries a preamp, available online and in some stores. You can also find preamps online (here's one at Amazon). With the preamp connected you can use any free input on the receiver.
Jun 05, 2011 | Stanton T52 Turntable
Faint sound slight buzzing
Connect it to the PHONO input of a receiver that has one or get a PHONO preamp and place it between the TT and your electronics.
http://en.wikipedia.org/wiki/Phonograph
May 21, 2010 | Stanton T52 Turntable
I can barely hear the record when played on my Stanton T.52
Is this a sudden onset problem or has it always been like this?
A traditional turntable requires a Phono preamp inline with it to PRE amplify and frequency-balance the minute signal produced by it's cartridge for later amplification by a power amp. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Recent AV Receivers generally do not.
You don't say what electronics you're running this through. I suspect you have it jacked into a Line Level input instead of a specific Phono input. The result would be very low, tinny sound.
If so, you need to get a Phono Preamplifier.
Feb 19, 2010 | Stanton T.50 Turntable
I hooked up my new stanton t-60 turntable to an older sony amp that does not have a phono jack. i used a behringer pp400 preamp to connect the turntable to the amp. the sound is coming through with heavy...
Are you using the phono input on the Sony? If so, you're getting too much gain, you've already got a phono pre amp in the Behringer. Try using the tape or C.D. input. That should solve it.
Jan 16, 2010 | Stanton STR8-60 Turntable
Phono plays lower in volume than cd and tuner. Sounds ok i guess but is about a quarter to one third lower in volume. Is this normal ? Can I plug phono into cd jacks to check if any better ?
Hello. As per the post before me, if you have a receiver with a Phono input(many receivers don't have one anymore) the output of a phono cartridge is around 30 millivolts, vs 300 millivolts for a CD(10 times the amount) or any other line level device. A Phono preamp, also has RIAA(recording engineering standards)Equalization that provides the proper equalization for a Phono cartridge. As per the other post, yes, it will sound very low, and unnatural sounding. If the input you are plugging the turntable input into, doesn't say Phono, you can purchase an inexpensive Phono preamp made just for this very issue. You can try Radio Shack, or find something of better quality on the Internet.
Regards,
Dave
Jan 11, 2010 | Pioneer VSX-453 Receiver
TurnTable left channel no signal
Somewhere in the jack or the plug you have a wire broken. You will just have to look for it. If you have a volt ohm meter, this will aid you in finding the broken conductor. When you find the bad connection, you will probably have to solder it back together.
Dec 29, 2009 | Stanton STR8-80 Turntable
234 people viewed this question
 Grubhead
Grubhead
