Question about Sharp AL-1641CS Laser Digital Copier
Locked up AL-1642CS with blinking Drum Light
I had a blinking drum replace light and the machine would still not copy anything, it's suppose to copy until the light is on continuously. My drum counter is showing 016018 copies. All of the buttons on the consol are not funtioning. All I can do is turn the machine on and off and it goes through its warm up routine.
I also see a bunch of suggestions to reset the drum counter but like I said above the buttons are not functioning after the warm up period. I also don't see the buttons " * " and " # " on my key pad. Help! I've already purchased a new drum and TD cartridge.
  • 1 more comment
  • FIREDOG3722 Nov 07, 2008
    Everything looked fine. Reset the counter and it started to work again. Thank you very much.
  • alpinefamily Nov 13, 2008
    I am also having the same problem, but our model # AL 1655CS. it is locked up and I have tried the sollution that was suggested for the previous post and it didnt work for me, any ideas. We have just replaced the ink and drum. The blinking drum light had been blinking for over a week.
    Thanks for any help on this.
    Crystal
  • msheinzel Feb 17, 2009
    Flopez,
    When I tried your sequence as stated above after Pressing 07 and and start nothing happened.
    The 1st time I tried it 000 flashed. The second time I tried it - nothing happened. The screen just stayed reading 07.
    Any suggestions? THANK YOU!
  • 161 Answers
Older Sharp AL copiers will go on working with the drum light blinking, but yours will not. Newer models do stop working when the drum reaches its limit. Now keep in mind that just as almost every copier in the market, these units count the copies they make in order to determine toner & drum life. So it is possible to reset the drum counter if you inspect the unit and see no markings or visible wear & tear. Also keep in mind that the toner & drum units have been the same for all AL units through time, so there are plenty of good replacements in the market (not recycled, but re-manufactured or brand-new compatibles).
As for your unit, if the drum is Sharp original or a good quality replacement, you should have to do nothing after installation, for the internal chip in the drum will tell the copier to reset the counter and begin working automatically. However if that is not the case, or should you want to reset the counter on your existing drum, this is the correct sequence to do so.
  1. Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying.
  2. Now press the following sequence of buttons: [CLR], [EXPOSURE], [CLR], [EXPOSURE]
  3. Your unit should turn off the numbers in the panel.
  4. Now press 24 as if asking for 24 copies and press [START].
  5. Press 07 as if asking for 7 copies and press [START].
  6. Your unit should restart by itself and start working normally.
Be blessed.
Posted on Nov 07, 2008
The red drum light is blinking and it will not make copies
HI drum is reach for end of life thats why drum light is blinking you shuld have to replace the drum or just reset the drum counter to run your machine for another life .
thanks
May 11, 2010 | Sharp AL 1631 Copier
AL 1631. Indicates that a drum has to be
To reset the drum light press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Feb 13, 2010 | Sharp AL 1631 Copier
My Sharp 1642cs says replace drum cartridge on the lcd. Even installing a brand oem drum cartridge. It will not function at all. How do i reset it?
Reset the drum count by pressing "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode"
Exposure mode is far left key on panel. You need to do this fairly quickly so that the display goes blank.
Once display goes blank then key in 24 then press print, then key in 7 then press print. You should now be getting flashing 000
Turn machine off then on and light should be gone.
Short version: C,far left,C,far left,24,print,7,print
Dec 09, 2009 | Sharp AL-1642CS Copier
Al 1642 cs drum light
You need to press These keys; C- Auto- C -Auto , Display off.
24 Print, 7 Print , 00 will display then press C twice.
Jun 30, 2009 | Sharp AL-1642CS Copier
the clear key may be stuck which seems to lock up your machine. The procedure to reset the drum lite is clear, auto (exposure setting), clear, auto when hit in a timely manner the display will go blank. Enter 24 then press the start key, then enter 07 and press the start key again. If you can't get the keys to work the circuit board may have cold solder joints.
Good luck
Bob
May 03, 2009 | Sharp AL-1642CS Copier
Reset the drum on a sharp al 1661
Press c interrupt c interrupt within 15sec display goes off enter 24 press start button enter 7 press start button 000 blinks press ca to exit from the program or restart the machine.
Oct 21, 2008 | Sharp AL-1642CS Copier
AL-1642CS
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
Apr 16, 2008 | Sharp AL-1642CS Copier
Sharp al-1551
Did you replace the drum with a Sharp brand drum? I recently replaced a drum in my Sharp AL-1642CS, the replacement drum fits ok, and the lights you describe are gone now, but it does make an annoying noise that is new. I wish I would have spent the money to get a Sharp drum, then you can call them directly for support. When I have called them they have been very helpful.
Dec 14, 2007 | Sharp AL-1551 Laser Printer
Sharp AL-1641CS Laser Digital Copier Logo
297 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
