Question about Microsoft Windows XP Professional
Hi uplate I just want to ask if I want to change the Image and the data in SYSTEM PROPERTIES as this Image. Thanks for your help
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this regarding changing the desktop image?
    Scholar:
  • 53 Answers
C:\windows\system32
open up "oemlogo.bmp" using paintbrush and save again as oemlogo.bmp making sure that it is going to be saved in the same place ie c:\windows\system32
once done either edit the oemlogo.bmp file or create a new image file, making sure that your new image file is the same pixle size as the origional oemlogo.bmp file.
my current oemlogo.bmp file is quite small, but experement to see what is best.
I initially found out how to do this from the following link. not all systems have this oemlogo.bmp file but you should be able to create one and save it in the system32 folder without issue.
http://www.windows-help-central.com/xp-system-properties-logo.html
Posted on Nov 08, 2008
Hi, my syncmaster p2270 seems to have some kind of focus issue. Everything is sharp, but to the right of the visuals on screen there is a duplicate, reflection of whatever is being displated on screen....
Hi Jonhy, on the pc , try this steps:
1. At the mainscreen mouse rigth click and go to Properties
2. Go to Definitions and Advanced
3. A window with graphic board's properties will come up and the choose 3D setup/config (depending on graphic board mark)
4. Change from Direct 3D to OpenGL and then Apply and OK to close.
This procedure is to change from hardware aceleration to software aceleration of image on screen. As that it will be sent only one kind of image definition from the pc to the screen with no repeating or mirrowed data. Hope it will helps you.
Nov 04, 2013 | Samsung SyncMaster P2270 22 inch Monitor
I have changed my windows xp operating system to windows 7, now my graphics properties and audio properties are not working properly
Now you hve to download the media and other drivers update in the MSi homepage.
Just make sure when you download the drivers the OS should be in the Win 7 format.
unzip it afterward, let the system automatically detect the drivers.
Thanks for asking FixYa!
Sep 13, 2011 | MSI K9AGM2-FIH - Motherboard - micro ATX -...
I have a problem with my samsung portable hard drive, it caught a virus and i can no longer access my files. it shows nothing yet when i check properties it says that my files are still there, what can i...
It is due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files. This can be fixed and data would be available to you. However, there are number of steps involved.
It is suggested that go to FOLDER OPTIONS - and select 'SHOW HIDDEN FILES & FOLDERS' and uncheck/ Deselect 'HIDE PROTECTED SYSTEM FILES'.
It would show the hidden files/ folders, if the system not infected Otherwise, from the clean/ virus free system you can see your data and copy all the required files/data. Select the required files and right-click and change the properties of the file by un-checking the hidden attribute. Please note that you can not change the properties (hidden attribute of the files) if the files are marked as system files. To change the attribute of such folders you can download and use iReset. Just drag the files/ folder to the iReset and it would change the folder attributes to normal and you would be able to view the files normally.
Also, make sure that you have a good antivirus installed and its updated. Scan your system and clean it.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 20, 2011 | Samsung S2 Portable External HXMU010EAG32...
I have a WD my book drive. When I try to see the files on the drive they are Not there, But when I click the properties the drive shows half the drive space is used. how do I get the files to show be...
CreativeTECH
Jun 04, 2011 | Western Digital My Book Essential Edition...
Hi Bubbabear64
If this a Royale Version of Windows XP, it should indicate that on the properties screen. The serial number should be on this properties screen as well.
There isn't anyway to change the properties screen. It's a proprietary screen that Microsoft use to read the serial number of the software, Bios settings of your computer, as well the processor and available memory you have.
Since these fields aren't populated, are you sure this is a genuine version of Windows XP?
Nov 07, 2008 | Microsoft Windows XP Professional
Hi Marked
I'm fine , by the way why do you want to changed the picture there?
Following installation of Norton 2008 all pictures viewed through internet explorer are poor quality and pixilated
Do you use ie6?
IE6 is set up to resize the images based on the Display DPI setting. You can either set the DPI to the default (Normal - 96) or remove IE6's UseHR registry key to deactivate image resizing. Here are the relevant information (from Microsoft Knowledge Base):
Image Scaling in Internet Explorer (hi-res)
How to Activate Image Scaling
Internet Explorer 6 and later automatically adjusts the scale on higher resolution systems when the DPI setting is higher than 96 DPI and the "UseHR" registry value is added to the registry. These are usually done by the manufacturers of higher resolution systems.
_registry() warn.gifWarning!!!: Using the Windows Registry Editor incorrectly can cause serious problems requiring the re-installation of your operating system and possible loss of data. I do not and will not support problems that arise from you editing your own registry. Use the Registry Editor and my directions at your own risk. Be sure that you create a backup of your registry and be very sure that you know how to restore it. If you are not sure how to do both of these things then STOP here!! and read the directions.
Set the DPI
These are the steps for changing the DPI setting on your system.
    Right-click the Windows desktop to display the context menu.
    Click Properties on the context menu to display the Display Properties dialog.
    Click the Settings tab on the Display Properties dialog to display the Settings tab.
    Click the Advanced button on the Settings tab to display the monitor properties dialog.
    Select a DPI setting in the Display frame of the monitor properties dialog to change the DPI setting.
    Restart your system to allow the changes to take effect.
    Add the UseHR Registry Entry
    The UseHR value is added to the Main key under "Internet Explorer" as follows:
    HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
    Right Click in the right pane and select New>DWORD value and set its data to 00000001
This problem can also be caused by bad video drivers. Update your drivers from the manufacturers site.
Jul 06, 2008 | Computers & Internet
ACER ASPIRE 3000
What new softwares or updates have you just done on the Aspire 3000,You need SP 2 Updates to function properly...
Change cmos back to default and then reboot
don't touch cmos anymore
FOLLOW THESE STEPS
after start up.
go to desk top
right click on the desk top
properties
display properties opens on themes
select settings
Now with Both screens attached and powered up
box 1 displayed will allow you to adjust the properties here.
Adjust to the smallest settings first should be 800x600
and this will allow you to independantly set sizes of image for each screen.At 800x600 both screens will be identical in size in the menu box.
Screen Number # 1
click Idendify,& number 1 should appear on your screen
click advanced
select compatibilty click apply without restart and OK
Screen Number # 2
DO the same process as Screen Number # 1
image size here needs to be 800x600 too
If your video does not run it will be the screen settings I have just talked about unless you have other softwares as a default.
Remove the other softwares and try again.
You should be able to save the settings for a dual output or set output to individually operate either or.....
I hope this helps your situation,
Please rate me or if you need more help just ask thanks
Jun 21, 2008 | Acer Aspire 3000 Notebook
Cannot get date appeared on pictures.
The date doesn't actually appear on the image. It's embedded in the data. You can see the date/time stamp by right-clicking on the image and selecting properties. You should see the date taken, date modified, etc..
Oct 25, 2007 | Fuji FinePix 3800 Digital Camera
Microsoft Windows XP Professional Logo
107 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
