Question about ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM W/L) Motherboard
MAX CAPACITY OF RAM MEMORY SUPPORTED BY THIS MOTHERBOARD
I need to know wich is the higuest capacity in RAM memory that asus a7n266-vm support
Thank you
  • scotttalbert Dec 01, 2008
    is that per slot, or total. in other words, can we put 1GB in each, or just 512MB?
Hi
the highest capacity of ram is one gb
lucky
Posted on Nov 16, 2008
Compatible memory at 2gb capacity and video card for asus p5pe-vm motherboard
Hi, you can download a manual here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR RAM memory
1 x AGP 8X slot.
Hope this will help you.
Aug 14, 2011 | ASUS P5PE-VM Motherboard
I want to upgrade my RAm from 256 to 1 gb DDR 1 , Dose A7N266-VM Rev -1.05 mother board supports it ?
amd processor? yes you can upgrade it and do not install the 256mb ram together with the 1 gb memory that you want to upgrade, better use the 1GB alone,
Aug 04, 2011 | ASUS A7N266-VM Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Asus motherboard( A7N266-VM)
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defaults.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 11, 2009 | ASUS A7N266-VM Motherboard
Memory problem
The ASUS web site shows only two ram slots on the motherboard. Sounds as if the booklet has a misprint. Specifications on the web site list memory as: Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR SDRAM memory. So, 2GB is max.
Jun 10, 2009 | ASUS P5PE-VM Motherboard
Need assistance for download ASUS driver cds
Hi vivek_anand2,
Asus no longer sells the CD for your motherboard. You'll have to download the drivers from Asus & burn the drivers to a CD/DVD disk.
Click on this Asus link;
http://support.asus.com/download/download.aspx?SLanguage=en-us
Once loaded type, A7N266-VM into the search window in the upper right hand corner of the page & click on the white arrow. Asus will load another site. The first one listed, A7N266-VM related files for download . Click on it. Another link will load & here you'll have to click the dropdown menu & click the operating system you are using or going to use. Than click, the search button.
All the drivers for the motherboard, A7N266-VM are listed there. Click the + sign to open each set of drivers.
If you need further help just post back here.
Good luck vivek_anand2!
Thank you for using FixYa.
Mike
Mar 22, 2009 | ASUS A7N266-VM Motherboard
I want to install/download asus A7N266 VM motherboard cd
Follow the link below
you'll need to input what operating system you are running
http://support.asus.com/download/download.aspx?modelname=A7N266-VM&SLanguage=en-us
Let me know if this helps.
Mark
PS. thanks for the rating
Motherboard problem
goto the above link and enter your model number into the search and it will tell you to select your os and then it will bring up a bunch of drivers for your board
Oct 04, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM W/L) Motherboard Logo
124 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
