I am unabke to fully uninstall HP Colour Laser Jet CM1015.CM1017 MFp 1.0 software. Some has been removed down to 33% then it just remains at 33%. I have tried switching off PC and starting again, each time removal gets to 33% then stops.
SOURCE: hp color laser jet cm1015
What is the error message? If ANY of the cartridges are empty, the printer will not print.
SOURCE: My HP Color Laser Jet CM1015 MFP started
There could be several reasons for this. Try the below steps one after another to check if this fixes the issue.
Step 1
The moisture content of the paper might be uneven, or the paper might have moist spots on its surface as a result of environmental humidity. Store the paper in a moisture-proof container. Try removing the top few sheets of paper from the paper tray or use paper from a different source (such as another ****), or try a different brand of paper.
The paper lot is bad. The manufacturing processes can cause some areas to reject toner. Try a different kind or brand of paper.
Step 2
Run the MPF cleaning utility from HP ToolboxFX
Cleaning of the Toner as well.
Step 3
Replace the Cyan(blue) toner as it may be low on ink
Thank you for contacting FixYa
* Please rate this solution with Thumbs up and comment to help us improve providing support
SOURCE: How to uninstall the HP Solution Center & other software
FEW WAYS TO DO IT I MEAN REMOVE PROGRAMS OR PRINTER DEVICES BOTH WAY REQUIRE TO GO INTO THE CONTROL PANEL:
SELECT PRINTER, RIGHT CLICK MOUSE BUTTON AND GO DOWN TO DELETE
AND FOLLOW INSTRUCTIONS
AND
2ND WAY
GO TO PROGRAMS AND FEATURES
OPEN THE FOLDER
WAIT FOR THE PROGRAM EXPAND
GO DOWN TO THE DRIVERS OR PROGRAM
YOU WANT TO REMOVE
THAN SELECT THE ITEM AND RIGHT CLICK IT
AND FOLLOW THOSE INSTRUCTIONS
REBOOT
EVERYTHING WILL DELETE AFTER REBOOTING THE SYSTEM AND THAN IT WILL DO SOME WINDOWS UPDATING TO HELP WINDOWS HELP WITH THE NEW CONFIGURATION SETUP OPERATIONS
