Question about Sony KP-53S65 53" Rear Projection Television
My sony projection tv colors dont go together right and the text banners. The picture is good when there is no text on the screen but when there is the text will not fit the screen an will banner on the top and bottom. what could this be.
    President:
  • 3,130 Answers
Its a common convergence problem here it sounds like.. These are IC's that are soldered int place and are standing up against a heat sink.. if your good at soldering, you should have No problem.. they stand up and start with STK . if you have no solid state experience,please call out a pro to assist you in this repair Please dont forget ti rate this
Posted on Oct 16, 2006
My sony kp 53v75 projection tv has an issue right now. The screen has lines that run horizontally across the screen that slightly distort the image. They move up and down slowly on the screen, Is there any...
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 22, 2010 | Sony KP-53V75 53" Rear Projection...
Sony KP 51 HW 40 - in left half of screen picture has double images, right half of screen picture is normal.
This problems very common on DLP Tvs.This problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board is dead.Require to be replaced on the tv convergence board 2 STK convergence ICS and some or all it resistors to solved the tv convergence board problems,to solved tv convergence picture problems.The shop,will cost about $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Colors run together,picture out of focus
Your tv needs the convergence re-aligned, look into the owners manual or call the manufacturer to get a walk through of how to do it. It will be in the menu of the tv under convergence.
May 05, 2010 | Sony KP-51HW40 51" Rear Projection...
56" sony rear projection picture problem
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 12, 2010 | Sony KP-57WS500 57" Rear Projection...
Picture goes blank AND SOUND goes off together, both back on too
it can still be the lamp for some reason these sony tv's will exibit these symptoms when the lamps are getting weak. by the way when the lamp goes out the entire tv shuts off no video or audio, just to let you know.
Aug 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Text/images overlap each other in 3 colors, 3D distorted picture
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture looks curved (concave curve) on my sony KP-46WT510
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
May 21, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony big screen tv, no color
focus block or neck boards on thr picture tubes
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
I have a double picture on screen i could hear my TV but the color are off too with Sony RM-Y908 Remote Control? which is broke
  • Screen looks 3D
2c07611.pngSolution
Oct 29, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
