GT5026E desktop My screen goes blank but power on monitor is on. Sometimes when moving mouse or clicking. Can turn off monitor and turn on again and will work for different amounts of time. novice, linda
Posted on Nov 07, 2008
Within the last few days the moniter "blue light" when it is turned on suddenly turns yellow and the screen goes dark. I move the mouse briskly and turn the moniter off and on again and...
You should check the "Power Options" when the computer "Sleeps" & "Hibernates". Go to the "Control Panel" if you Win 7 or below, if you have Win 10 just type "Power" on the "Search Box" on the bottom left of the screen and then click "Edit a Power Plan" and set when the Computer "Sleeps" and when it "Hibernates". Basically when you move your mouse you are waking up the Computer from "Sleeping" or "Hibernating". Goodluck.
Dec 14, 2017 | Acer Brand ACER P191W 19" LCD Monitor
How to shut down a computer?
1. Close any applications you have running, such as your email or instant messaging service, by clicking the "X" in the upper-right corner of each program page.
2. Left-click your mouse on the Start button, typically found in the bottom-left corner of your computer screen.
3. Highlight the option to "Shut Down" and left-click your mouse again to initiate the proper shutdown process.
4. Wait until your computer logs you off of any applications, your computer screen goes blank and the power light turns off before you turn off your monitor or close your laptop.
Dec 23, 2010 | Computers & Internet
Samsung 22inch lcd monitor goes blank after 1min idle system.
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
Black screen
Sounds like your screen is being switched to "Power Save" mode due to inactivity. This should switch back when the mouse is moved. This can take several seconds on a laptop. You can remove this "Power Save" by right clicking anywhere on blank desktop, select "Properties", "Screen Saver" and "Power Settings" then select "Always On" for the monitor.
Sep 13, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
Monitor picture turns on its side when it goes to screensaver
Sounds like your screensaver is using a picture of your desktop in it's code intentionally.
Right click on a blank area of your desktop --> select properties
--> click screensaver --> change it to "none" or another screensaver
Jan 17, 2009 | CTX S762A 17" LCD Monitor
Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Monitor keeps turning off
my first two ideas are....
1. Power setting/screen saver - this could be build into the monitor or a setting in the power options in the control panel.
2. improper setting for the monitor....this could be the refresh rate most likely.....right-click in a blank area of the desktop, go to properties, settings tab, advanced.....there should be an option in one of the tabs that has an option for refreash rate...make sure it is set to 60.....
If not one of these two things, than it is a faulty monitor......probably not worth getting fixed....hopefully still under warranty??
May 18, 2008 | Proview PL926WBi 19" LCD Monitor
Screen goes blank when I move the mouse
please be specific, your question is not understood properly??
Oct 26, 2007 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
646 people viewed this question
David Payne
David Payne
