Question about GE ZSC2001FSS Advantium Electric Single Oven
Door is loose
I cannot figure out how to tighten the door handle on the oven?
  • gatsbydog Dec 02, 2007
    My door handle is loose. The screws on the door frame won't budge without overwhelming force that I am not willing to apply. There are caps on the end of the handle that move but I can't get them off either. Help!
  • 4 Answers
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Posted on Dec 26, 2007
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
How to tighten loose handle
Remove the door gasket, that should give you access to removing door plate. Door handle may need to be replaced.
Oct 26, 2013 | Combi Steamer electric built in steam...
Open door handle is loose on a true temp GE stove how do I tighten the handle
You will need to unscrew and unfasten the inside door panel to access the screws that need to be tightened.
Jan 06, 2013 | Ovens
Oven door handle is loose on Model RF366BXD self cleaning range, how do we tighten the door handle?
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Unfortunately, to get at the interior of the handle unit, it's the final stage of the taking apart. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. (You can give your glass a good cleaning at this point also.) There are 2 bolts to remove to free up the handle unit, and now you can easily tighten (or replace as needed) the 2 pairs of handle bolts. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Dec 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven door handle is loose and needs to be tightened
You will have to remove the door from the oven to do this, for a full explanation on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter--- CLEANING OVEN DOOR GLASS, this will give you details on how to remove door and disassemble.
Dec 01, 2010 | Whirlpool Ovens
Loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Jan 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
GE ZSC2001FSS Advantium Electric Single Oven Logo
149 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
