Question about Canon PIXMA MP160 All-In-One InkJet Printer
Alarm and power probelm
My printer has problem with their power unit,... the alarm power is on but the printer power is off.... i has already try to reset it but stilldont work... ill try change their catridge in case if there are plblem with it catridge head but its sill won work.... now im open the printer casting and try to look at their hardware but still cant found the issues... pls help me u can contact my email at pengenmaen@yahoo.com for the solution.... thank you very much sir
    Guru:
  • Canon Expert
  • 183 Answers
Dear pengenmaen,
It seem that the logic board of your printer is faulty. Mostly caused by short circuitry in your printer. Be careful that the most dangerous short circuitry sometimes cause the carriage part is faulty too. So, you'd better to replace both logic board and carriage part if you can do it by yourself. Otherwise, i suggest you to bring the printer to the nearest service center in your location. This problem commonly occurs in case of usage of refill ink. Also try find useful article about canon inkjet printer here: http://www.ij-forum.blogspot.com.
I hope this will be useful for you and please give your rating
Regards,
Posted on Nov 08, 2008
Front cover is on alarm even the front cover is already closed. how can i reset the alarm.
Hello, Did the technician ask about any error codes in display?
For Example the number 2 from the center picture on display ( the picture of machine) or by pressing and holding the * (star) key on number pad show 2 numbers with the second being 817 in the red number area?
When the door is closed there is a one inch thin piece that gets inserted into a slot that activates a switch proving the door is closed..
There several resets you can try - holding down reset while powering on machine, Holding down just the "print position" left and right arrow keys (not the center) . and powering on equipment then typing "94" and then press start key. Note press clear if any numbers show up before hand.
If no results the part on door has broken or the switch is out of position to activate correctly,
Please tell any codes and we can go from there. TY
Jan 29, 2015 | Riso RZ220 MASTER UNIT - ONE ROLL PACK
Alarm po2 after off the power only 4 print and alarm again po2 then afte off the power again only one and alarm again po2
  • p02 is normal issue clean the purge unit and align carriage plate screw problem is solved
  • Or you are using ciss tank properly fix the ciss tube problem willb solved
Mar 15, 2014 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Nissan alarm
try and find if there is a sensitivity adjustment for the alarm and set it to a lower setting
Jan 11, 2014 | 2004 Nissan XTerra
ALARM light is on, and not able to print I already
Try this reset on the printer
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
  5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My Brother HL-1440 Laser printer is not printing. Whenever I try to print something there is a sound coming from the printer with a high tone, then a low tone. This is the first time I have experienced...
this is normally a symptom of the Fuser unit failing within the printer. our company uses nothing but Brother printers and i have seen this error a few times.
on very rare occasions its not the fuser and unplugging the power lead and leaving it for ten minutes will resolve the problem. if you have already tried this however the problem your getting is to-do with the Fuser unit within the printer being broken..
unfortunately from past experiences a replacement fuser unit for one of these laser printers is actually more than the cost of a new laser printer...
a quick google search revealed this site who are offering fuser replacements for $119.00
http://www.precisionroller.com/fuser-assemblies---units-for-brother-hl1440/products.html
hope this helps.
Apr 28, 2010 | Brother HL 1440 Laser Printer
When power up I get E14 error and alarm an
Maybe you have inserted the faulty or refilled cartridges.
Nov 03, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Paper jam alarm in, but there is no jam.
try to reset the printer or turn it off for 1min and then back on. That should work.
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Tally printer hardware alarm home postion
There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
Dec 07, 2008 | Tally T2250 Matrix Printer
If you already took the printer apart, check the socket where you connect the printer to power, check that the connector soldering joints and contacts are not broke.
The circuit area near the AC adapter socket on the printer is the power board.
If there is a fuse check it.
If there is smell or trace of burnt, that means that a component, usually a capacitor, had blown.
If you do not find anything it must be the AC adapter terminal cable, or the connector , that has a broken contact.
To test it you need to get a multimeter and measure voltage from the AC adapter connector. Alternatively take the printer to a repair shop , tell them that you want to buy a power adapter for your printer, and ask to test a spare power adapter first. Many shops do not charge repair fee for this, as long as it can be done on the fly, and printer must not be left in for repairs.
Nov 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Alarm problem
Have you tried to disconnect the printer and then reconnect it?
Jun 07, 2017 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
48 people viewed this question
old marine
old marine
