Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Seaco Royal grinder not working
My grinder is not getting power 80% of the time so the grinder's motor is not turnig pouring clean water in stead of coffe. Some times it works but most times dont. The rectifier bridge(D1) that powers the grinder's motor is also not getting 110 VAC, in fact i have permanent 110VAC all the way to T5 and T6 on one leg but when you push the button ta make coffe T5 & T6 does not open to pass the 110vac to it's center leg which furture will supply D1 rectifier bridge with AC for grinder's motor. Any one? what can cause this?
  • rudarel Nov 08, 2008
    This FixaYa site is the biggest scam ever, nobody ever answer to any questions, the existing questions are posted and answered by the same idiot logged in under a different name. i'm sorry to say I paid $14.99 for live chat and nobody ever answered, after one hour of waiting like a fool my live chat session expired so I e-mailed FixYa support about it but nobody ever answered. There is no refund also since you can't get nobody to talk to you. So don't pay here or you’ll get scammed.
    Problem Solver:
This FixaYa site is the biggest scam ever, nobody ever answer to any qwestions, the existing qwestions are posted and answered by the same idiot logged in under a diferent name. i'm sory to say i payed $14.99 for live chat and nobody ever answered, after one hour of waiting like a fool my live chat sesion expierd so i e-mailed FixYa support about it but nobody ever answered. There is no refound also since you can't get nobody to talk to you. So don't pay here or you'l get scamed.
Posted on Nov 08, 2008
3 Suggested Answers
mirran
  • 515 Answers
SOURCE: Seaco Royal grinder not working
Sorry you not get any good answers here, i where her regulary before and answer questions, but now i´m on sick-list and have not access to computer regulary. After 1 December i will be online again.
Now to your problem, if the grinder not grind like it does before it can be the printed circuit card that has to be replaced.
Try to check the grinding engine to see if it looks ok, you can also try to measure the grinding engine.
Let me know if i can help you more.
Best regards
/Mirran
  • 1089 Answers
SOURCE: Grinder not working
Hi
First off the grinder motors are 110V DC not AC. I would say that your problem is in the micro switch for the doser box under the solenoid. It sounds like it might be stuck closed and that would by pass the grinder saying the the doser box is full and don't run the grinder. You may just need a new micro switch which is specialized.
Posted on May 24, 2009
My Seaco Royal Machine has got double problems. The first one is; water dripping from the bottom to the floor. The second is; coffee coming out slowly (drops ). The second is; the sounds that accompany the...
The leak may be due to a clogged weep passage that resides behind the brew group and empties into the drip tray in the front. Take a long piece of wire or a good paperclip and straighten it out. Take some hot soapy water and a small syringe and wash that area out with the drip tray installed. As for the coffee coming out too slowly, you may want to adjust the grinder to a more coarse grind by one or two clicks. After each single adjustment to the grinder, it will take two brew cycles to catch up to the adjustment. Don't make too many adjustments without running at least two cycles in between each adjustment. If that does not solve the problem, you may need to take it to the repair center nearest you to have them check out the pump.
Feb 03, 2014 | Saeco Royal Professional Espresso Machine
I have a seaco royal coffee machine and it keep telling me to fill water tank when its full. what can i do
Hi
Go into the menu.
Scroll with the arrows on the panel until you get to "Direct Water Connection".
Push the menu button, and chose "OFF", then push the menu button again, then esc. button twice and it should go away.
Dec 04, 2010 | Saeco Royal Professional Espresso Machine
How do I clean the bean grinder in a seaco royal profesionla machine?
These instructions come directly from the service manual. Notice the mention of a qualified technician. If you do this on your own be careful. If you don't follow the instructions correctly or you break something you've will have no one to blame but yourself.
-Clean the coffee beans container periodically; this operation should be accomplished by a qualified technician! Unplug the machine. Empty the coffee container and unloose the two fastening screws. Now, the container can be removed and cleaned.
-Carefully pull the adjustment lever upwards, previously writing the set grinding degree.
-Turn the adjustment ring counterclockwise, until the blue marks coincide.
-Now, it is possible to remove the grinding ring from the machine, slightly pulling it upwards.
-With the aid of a brush or a narrow vacuum hose, clean both the gear box and the grind ring support. Make sure the position of the grind ring does not shift. To reassemble the coffee grinder, carry out the reverse sequence, making sure the adjustment ring has not been shifted during cleaning. If that is the case, turn it until the blue mark coincide with one of the three notches. Assemble the grind ring support and make sure the blue marks coincide.
-Turn the adjustment ring clockwise, to make the red marks coincide.
-Fit the adjustment lever on the ring, until it coincides with the previously set grinding degree.
Nov 28, 2010 | Saeco Royal Professional Espresso Machine
I have a Seaco Royal Professional coffee machine and it is telling me to ventilate, what does this mean and how do I fix this problem?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out. This mean that any steam or air blocked in the water system must get out from steam wand.
Good luck
Jul 26, 2010 | Saeco Royal Professional Espresso Machine
Grinder blocked
One posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
Jun 04, 2010 | Saeco Royal Professional Espresso Machine
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
On our Seaco Professional the water tank is full but says empty
On the corner of the water is there a black rectangular float, if yes then the water sensor is probably not connected.
Mar 27, 2009 | Saeco Royal Professional Espresso Machine
Best regards
/Mirran
Nov 07, 2008 | Saeco Royal Digital Plus Coffee...
Grinder not working
Hi
Beans won't grind
Try cleaning out the grinder with the instruction for this link: http://www.cerinicoffee.com/Saeco_technical_documents.asp
Polyglot, if you have done this already it sounds like there is something wrong with the grinder switch on your machine. You will have to get the machine serviced.
We service saeco espresso machines based out of New York.
Checkout our website for more information: www.CeriniCoffee.com
Youngie,
Your problem is not the same as Polyglot. Try cleaning out the grinder using the link above. It works 50% of the time. For some reason your machine is not grinding. Common reasons are water has been accidentally spilled in the bean hopper or the grinder just has a problem and needs to be addressed.
In the case where water spills into the bean hopper you may need to change the grinder burrs. (http://cerinicoffee.com/Grinder_burrs_saeco_gaggia.asp)
Hope this helps.
Apr 02, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
100 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
