Question about RCA R56WH76 Projection Television
RCA R56WH78 3D Color Spectrum
Hello my RCA R56WH78 TV has gone bad. The colors are all unaligned, giving it a "3D" look. I have read up on the issue and hear this is often a fuse that has blown. I know its around $400 to fix from a professional. I am going to be risky and try to fix it myself, but I need to know for sure its the fuse that is the problem. Also I don't know what website has good parts, I have read if you don't get it from the right place most of the time it will go bad very quickly. Lastly I need to know if anyone knows where to find the "Blueprints" of the inside of my TV [forgive my forgetful vocabulary=( ]
Thank you for your time and help!
  • 1 more comment
  • JonnyCarlyon Dec 04, 2008
    Willtab, Thank you after a little confusion and replacing the wrong fuse (and realizing that) replacing it was a breeze! All thanks to your help though, Thank you very much!
  • ldcathcart Dec 04, 2008
    i have the same problem. the fuse has been replaced by a repair shop once and lasted four days, then i replaced it and it lasted ten days. what could be blowing this fuse?
  • Anonymous Feb 16, 2009
    I HAVE THE SAME PROBLEM MY TV IT LOOKS LIKE 3D AND I DONT KNOW HOW TO FIX IT?CAN ANY ONE HELP ME
    Genius:
  • 1,030 Answers
Hello The common FL231 fuse problem that these set has can be identified by asking the question DO you have the convergence option under setup in the customer menu. If you do not then there is a 99 percent chance you have this. I have written detail repair instrucitons on this under my profile in the tips and tricks section of fixya. I use union electronics for parts but just google the part and you can find many distribitors of the fuse. should not cost no more than 5 dolars and if you can solder the repair shouldnt take more than an hour to complete. Be carefull and good luck. This repair is on you can do if you have any trouble let me know.
Posted on Nov 14, 2008
  • Willie Howell Nov 14, 2008
    sorry last sentence should read/..... This repair is ONE you can do
My RCAHDTV has misaligned colors, 3D effect. how can I fix it?
Thank you
Posted on Mar 28, 2009
    Problem Solver:
  • 10 Answers
Go to this site and buy the fix kit for $25
http://www.tvrepairworld.com/rca_repair_kits
Posted on Sep 27, 2009
My RCA scenium hdlp50w151 TV is making a whirring sound. Just replaced lamp and have no picture...
Hello,the color wheel has gone bad, thats what the noise is, the bearing goes bad and it won't spin fast enough for the sensors to let the set come on. You can buy them and there's a video on youtube on how to change it....tks
Aug 17, 2014 | Televison & Video
RCA 42" Projection TV
Did you cheak the bulb? I believe those also have red yellow and blue lights to make up the color spectrum you should check all of these bulbs
Feb 29, 2012 | RCA Televison & Video
Limited color on screen primarily blue, white and green. I use to be able to fix by giving the screen a gentle wiggle but color spectrum is gone.
Sounds like you have a bad joint on the tv circuit board somewhere.There is another thing it could be if you have a scart lead connected. Pull it out and check to make sure none of the pins are dissapearing inside the plug. Sometimes they slip inside. Check both ends of the lead.
Feb 16, 2012 | Panasonic TCP42C2 42 in TV
I have a RCA HD50LPW42, the tv stopped showing the picture awhile back but the sound continued when the tv was turned on. Now the sound has gone out too. When I turn the tv on the green power light blinks...
You may have two problems with your TV. This TV has a history of a color wheel issue, was making grinding noise? Have you ever changed the lamp?
It may be a bad color wheel and the lamp, you may want to do a visual inspection.
It is easy to replace the lamp but more likely the color wheel is the problem.
The part# for the color wheel is 212184, the part# for the lamp is 260962
Best of luck
Nour Sabre
www.aaatvservice.com
Nov 16, 2011 | RCA HD50LPW42 50" Rear Projection HDTV
No red color in my Hitachi TV
there are three guns that produce color
red blue yellow they make the spectrum which includes black if one of the guns burn out you loose that color if the gun is good then the color board that controls that color is bad
Feb 26, 2010 | Televison & Video
Infocus 61 inches DLP-HDTV.
Infocus was always made by RCA for infocus the parts are straight RCA be warned that the parts for the RCA dlp's are very exspensive
Mar 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
NO COLOR IN MY RCA F36668 TV
Could be a bad TV or it could be loose TV connections feeding to the back of the TV. Any poor or loose connections in the cable leads causes a loss of signal strength to the TV.
Old cables and connection supplying TV Cable to the house or apartment can cause this problem also.
Dec 05, 2008 | RCA F36668 36" TV
RCA D52W136D 52 inch has no green
Hello sjustinh,
It sounds like your color processor may have gone bad or at least the circuitry connected to it. To solve this problem you will need a schematic, a digital storage oscilloscope, a signal generator, and a multimeter. Now if you don't know what these devices are and do not have a background in electronics, I would suggest that you take the TV set to a qualified TV repair person. I am not trying to put you down or anything its just that this problem requires that you open up the set and using the schematic trace down the signals that control the LCD screen and find out the condition of the signals that display green. Since green is the result of the algebraic addition of red and blue, you may have a problem in the circuitry that controls that function.
I hope this helps,
Thank you,
Shuttle83
Sep 18, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
Open Questions:
RCA R56WH76 Projection Television Logo
1,234 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
