Question about Jensen JPA1150M Car Audio Amplifier
Amp wont go off standby
Hello my friend has a Jensen JPA1150M Car amp and when he turns on his car the amp stays on standby. i cant figure out why this is considering when i hooked up his subs in my own car they worked just fine using my own amp. so i know its a problem dealing with the amp but i cant figure out what it is. any suggestions?
Vulfen
  • 5 Answers
SOURCE: Jensen LXA400
I have this same amplifier. I have noticed several ways it will "not work" during my ownership of it. I have it connected to a seperate battery to save my alternator, battery, etc as it is a power hungry beast for how low the output wattage is. Test the input voltage to see if you have enough, one way to see this is to check the "jensen" emblem that lights up. If you dont have enough power it will appear dim and only the right side lights up. Also the amplifier will not work if your speakers are "blown" even a little bit. Ive taken speakers that wont work on my lxa400 and connected them to a higher power amp and they will work (although they will sound horrible) If youre smart you will keep the gain under 3/4 on this amp, I see some people have found out the hard way that full gain fries the amplifier circuitry. Not an expert on electronics but it smells somewhat like melting glue or plastic. Ive noticed a lot of people have problems with the RCA jacks as well. There are 8 jacks, in two clusters. The first one is A+B and the second is C+D. Note: You do not NEED Y connectors on this amp! Connect your output rcas from the deck to top left and bottom left jacks of the left cluster. This will give you left and right (a+b) output from the first set of speaker outs. Then connect an rca patch cord from the top right and bottom right jacks of the first cluster and connect the other end to the top left and bottom left of the second cluster. This will give you output from the second set of speaker outs. Remember that this is in 4 channel mode. I dont remember the set ups for 3 channel but two channel I believe is the left deck rca goes to top left of the first cluster and the right deck rca goes to the top left of the second cluster. Then you just wire the speaker outs according to the picture on the amplifier. something like this: _________________________ |(+) - (-) +| ~~~~~~~~~~~~~~~~~~~~~~~~~ Speaker + goes to (+) and speaker - goes to (-) Also addressing another issue if you want to increase the wattage to your speakers you just use a lower resistance speaker (2ohm instead of 4) I would not recommend using anything over 4 ohms. As for the high level inputs, I dont recommend using them unless you have the plugs that go with them, its a lot easier to wire your deck rears to a line converter (changes straight speaker wire to RCA jacks) or to just buy a new deck with RCA outs. Last item, common knowledge: 400 watts does NOT mean 400 watts!!! This amplifier puts out very little actual wattage (50 or 83 per channel depending on the load) Hope all this helps someone out there.. Anyone who knows the 3 channel setups I would appreciate it.
Posted on Jul 15, 2007
  • 631 Answers
SOURCE: Bridging My AMP
This amplifier uses the left + and the right - for bridging. The manual is available from Jensen but you have to email them to get it.
Posted on Oct 12, 2007
jerryg50
  • 1673 Answers
SOURCE: Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Posted on May 01, 2008
zapco
  • 30 Answers
SOURCE: Hooking Up A Sony XM754HX To Jensen BP210
hi .let me see if i can help u out ...need more info on the speaker..are the 8ohm or 4ohm ? and are the single are DVC?.....from what i can see u can bridged the amp..and u must connet the subs in series or just connet each sub +/- to +/-..and that will give u a stereo mode... u will still get great sound
Posted on Jun 22, 2008
  • 4 Answers
SOURCE: Jensen VM9311TS wont play cd
but if the amp isnt powered on, how does it play during the radio? I have the same issue
Posted on Oct 13, 2009
SUBWOOFER AND AMP
Check the RCAs and make sure they are still connected. Check the speaker wires (both inside and outside the box). Check the remote turn on wire.
Jul 26, 2012 | Car Audio & Video
My jensen wont play cds wen it dose it skips
use a common cd/dvd optic cleaner .... they are cheap .. what is going on is your cd player cant find a track so it shuts off ..
Feb 10, 2010 | Jensen Car Audio & Video
I turned my car on and when the amp turns on one speaker pushes out and the other pushes in and stay like that and dont produce any sound. i checked the wires and fuses and everything is correct but i cant...
Hello mikhail_1994,
I'm assuming that the amp was installed and was working properly.
It sounds like the output is shorted. The CH450 may be operated as a 2-channel amp or both channels can be bridged for mono powering subs at an impedance of 4ohms or more.
I'd test the sub voice coils and then test each channel of the amp separately.
Hope this helps.
Jul 20, 2009 | Boss CHAOS CH450 Car Audio Amplifier
The red light on jensen 850watt amp wont turn off
jensen sucks dude. just sell it and upgrade. red light could be anytihng. chekc your speaker wires and make sure nothing is touching. from the remote start wire(blue) to the amps and subs. chekc and make sure there is nothing touching.
May 26, 2009 | Jensen Car Audio & Video
PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
May 24, 2009 | Jensen Car Audio & Video
Radio turns on but wont play any sound
you may have blown the out put chip in the radio
May 21, 2009 | Jensen MP7610 CD Player
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Jensen Amp and Sub
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
Power and Stand-by light alternate (JPA1150M)
It shouldn't be going into protection mode. Have you tried doing this on the other channel?
The high level input is for speaker level signal (as those you'd have if you were driving the amp from an OEM head unit).
Mar 27, 2008 | Jensen JPA1150M Car Audio Amplifier
Bridging My AMP
Oct 11, 2007 | Jensen LXA300 Car Audio Amplifier
Jensen JPA1150M Car Audio Amplifier Logo
79 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
