Question about Kicker KX600.1 Car Audio Amplifier
Kicker amo in my old vette
Hi, I have a kicker amp mounted in my rear deck for 3 years. I took the vetteout tonite and I noticed that when I turn up the volume above 50 or 60 % the amp goes into protected mode and the led turns red. After bout 10 seconds the amp led turns green and it plays as long as i dont turn it up too loud (50%max) why does the amp all of a sudden go into this protected mode? thansk i am not sure of the kicker model number
  • neshaminy Nov 11, 2008
    i traced the issue to the speakers. the front left speaker was "blown" which i believed was causing the amp to go into protected mode. i replaced the speaker and the problem went away. many thanks for your help!!!!!
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Posted on Nov 09, 2008
I had some kicker 6x9 cs693 installed in my 2002 camry rear deck and when they returned the car the spearkers are not producing much sound or bass. I am using factory stereo and also the factory 6x9 on...
first check to see that the fader is not programmed to the front speakers fading it rear might solve your problem, second if your stereo has a 4 ohm load requirement at the output and your new speakers are 8 ohms this will cut the power output in half, your best bet is to get an amp if these do not solve the problem.
Feb 27, 2015 | Kicker Car Audio & Video
I am adding a kicker 500 watt amp and a pair of 12" kicker subwoofers to my factory(non Boss - possibly Delco)audio system. I need to tap into the rear deck 6X9 bass speaker wires to make the kicker s
You will know if you have them O.O.S. ( out of synk ) they will simply not sound right. You want them hitting in the same polarity.
Make sure you check to see that you have disabled the on board amplifier(s) before just cutting the wires.
You didnt add any information about what type of automobile you have, other than saying "Delco" so I am assuming its a GM vehicle?
If so, you will want to Google " speaker wire color for (make/model/year)"
Jan 08, 2015 | Cars & Trucks
How do i wire a single 12" kicker cvr dual 2 ohm
Simple power fom amo to power on sub. Ground on amp to ground on sub
Feb 28, 2013 | Car Audio & Video
I have a 2004 GMC Envoy with a 1000 watt kicker amp with a 2000 watt kicker 15'' L7 and it will dim everything in it, I don't even have to have it really loud what do i do first?
1,what gauge is power wire? Must use 4 ga. minimum 2,what gauge and how long is ground cable? 18 inch maximum 3,battery amps is crucial,check battery fluid level 4,only old school kicker amps are 1 ohm stable,check amp specs
May 14, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
No power to my kicker ZX 1000.1
sounds like you blew a fuse for the battery power supply to the amplifier
Mar 23, 2010 | Kicker ZX10001 Car Audio Amplifier
I have a 12 kicker sub and a 600 wt power acoustic
there is a volume on the amp try that and the settings on your deck allow you to adjust your subs
Jan 15, 2010 | Kicker Car Audio & Video
Cut out
Do you have ONE pair of 12's? Are they single voice coils? Dual? Bottom line, you are either over driving the amp (bass controll up high on the head unit (stereo), or the "load" on the amo is too low, meaning 2-12'" dual voice coils parreleled would give you a 1ohm load. Need more info, need to know what the bass is set on on your stereo, what size power wire to the amp, and I can wrap up the solution. ok?
Take care,
Larry T
Winona Lake, IN
Jan 28, 2009 | Kicker ZX400.1 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Amp won't put out sound
Hello, if you leave me your email I can send you the user manual for this amp. Best regards, Arpi
Apr 10, 2007 | Sony XM-SD22X Car Audio Amplifier
Kicker KX600.1 Car Audio Amplifier Logo
185 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
