Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
Need to know which terminals run what
Old thermostat (same kind, honeywell 6300B) just replaced because the fan would never shut off unless we flipped a breaker.  All wires in heating/AC unit seem fine, so we got new thermostat.  When hooked up new thermostat as directed, would not even turn on (no response).  Need to know what the terminals operate, in case our heating/AC wiring is screwy.
  • 52 Answers
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Posted on Nov 07, 2008
How do I wire a Honeywell thermostat
Can I start by saying I am not in anyway saying to do this alone it is dangerous but if u must follow each step start by being safe shut off the breakers good luck here to help
Step 1
Turn the air conditioning and heating unit off by flipping the appropriate circuit breaker. Test the unit to make sure it's off by turning your existing thermostat to the "On" position and seeing if it turns on. Wiring a Honeywell thermostat when the circuit breaker is on could cause you to blow the transformer that powers the HVAC unit Step 2
Connect the red wires to the thermostat RH, thermostat RC or thermostat R terminal. The thermostat RC terminal has a jumper wire between thermostat RH and thermostat RC. The thermostat R terminal operates both the heating and cooling units, and contains an internal jumper wire. Basically, your red wire on a Honeywell thermostat is the hot wire that run. Step 3
Run the green wire to the thermostat G terminal. The green wire controls the relay that operates the blower, and it controls the fan. Step 4
Control your air conditioning when you connect the yellow wire. It connects to the thermostat Y terminal Step 5
Hook the white wire to the thermostat W terminal to control the heating unit
Nov 20, 2014 | Heating & Cooling
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Honeywell thermostat RTH6300b will not shut off at
I had this same problem with my 6300B thermostat. I did not see this when I installed the tstat and did setup for it the first time. If you go to page 16 of the install guide, there are instructions for setting up your tstat for your furnace and AC. The setting I had wrong was on page 20 of the guide. It defaults to a setting for a furnace/ac that is less than 90% efficient. When I changed the setting to a furnace that is more than 90% efficient, the fan not turning on or off problem went away. The setting on page 20 should be set to "3" if you have a more than 90% efficient furnace/ac. Hope this helps your problem
Jul 18, 2010 | Honeywell Focus 6300B 5-2 Days...
Replacing 9420 robertshaw hooking up 6300B honeywell. I have a wire (W2) i don't know what to do with?
If you have a single stage furnace, you do not need that wire....if you have a two stage, then you cannot use that thermostat because it will not do 2 stage...
Apr 28, 2010 | Honeywell Focus 6300B 5-2 Days...
My husband just installed the Honeywell RTH2310 thermostat. The fan turns on, but the furnace does not. What's our next step? (It's a natural gas furnace and he made sure that it is on correct h/e setting....
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Oct 20, 2009 | Honeywell Focus 6300B 5-2 Days...
I'm trying to install a Honeywell RTH2310B programmable thermostat. I only have 3 wires coming out of the existing thermostat (the red wire was attached to both Rc and Rh terminals). The other wires were...
Your house might be older.  Are your receptacles two-prong, or three?
I would ignore the missing "G" wire, and connect Red to both Rc and Rh, and Y to Y, and W to W.
Jan 01, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell 6300B clicking noise
I have the same model, and am also experiencing the clicking.
Jan 21, 2008 | Honeywell Focus 6300B 5-2 Days...
Honeywell 6300 programable thermostat instalation
The thermostat is a low voltage circuit (24 volts) most of the newer heating systems have a fuse for the low voltage controls. If you are having to re-set the high voltage circuit breaker, then you have something else wrong. When does the breaker trip? while its running or after it shuts off?
Nov 18, 2007 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
254 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
