Laserjet 2840 has error 59.4 have reset power several times but error returns when it tries to print
  • Anonymous Dec 04, 2008
    Same problem with HP LaserJet 2840 ( ERROR 59.4 ) at process COPY (after SCAN bewore PRINT).
  • Anonymous Mar 23, 2009
    re install is not solution for this error
Posted on Apr 30, 2009
    Sergeant:
    Champion:
  • 246 Answers
Please re install the printer driver
Posted on Nov 07, 2008
Hp 2840 error code 49
49 means data transfer error from your computer,please power off the printer and delete all print command from your computer ,try again best luck
Jul 11, 2014 | HP LaserJet 2840 Printer
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
My printer clj 2840 displayed error code 59.c0 when powered on. How do i resolve this?
This mean a main motor error occurred. X description: 0 = Motor error 1 = Motor start up error 2 = Motor rotation error
1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Oct 16, 2009 | HP LaserJet 2840 Printer
Hp color jet 2840 cannot scan on windows vista but can print
The problem is Vista. I had a similar problem and the only solution at the time was to remove vista and install good old reliable XP. Now just put windows 7 on and you should be ok.
Aug 14, 2009 | HP LaserJet 2840 Printer
HP 2840 ready yet prints only a white page
Did you resolve this issue?
If not check that the Scanner bulb is lighting. If not check the cable from the scanner to the formatter and seated correctly. The scanner or the formatter board may be bad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 09, 2008 | HP LaserJet 2840 All-In-One Printer
FUSER ERROR
I just reviewed both of the above fuser issues (50.2 & 50.3). Both are highly likely (even if recently replaced) fuser damaged. I have included below a link to a free HP service manual for your machines. Start on page 309 using a volt/ohms meter to test the fuser. To address the "Guest" inquiry regarding the HVPS, there is a separate HVPS however please be aware that it is not part of the fusing circuit in this machine. If anything it would be the LVPS (Low Voltage Power Supply) however very remote. Odds are maybe 1 in 200 on your best day. I'd put 10 fusers in the machine before I bought 1 LVPS. This machine is known to eat fusers. The HVPS and LVPS at this time are just about bulletproof. PLEASE TRY TESTING THE FUSER AGAIN USING THE MANUAL PAGE 309 TO 311. If your really want the power supplies though, they are on the part number list at the end of the manual. I just looked it up and we have repaired 74 of machines to date with not one PS ever used. 59 of the 74 have been for fuser issues.
Here's the manual link:
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%202820,%202830,%202840%20Parts,%20Service%20Manual.pdf
Hope that helps you both. :)
Jul 29, 2008 | HP LaserJet 2840 All-In-One Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
2,497 people viewed this question
k24674
jasbo
jasbo
