Question about Pioneer AVIC-D3 Car DVD Player
Navigation problem I just recently had this unit installed in my wifes car so I am not use to it, but it seems that the arrow is not following the road. Sometimes it is pointing to where I am on the road, sometimes seems to be sideways or even like I am driving bacwards.....Any suggestions?
  • 98 Answers
What is your model check to see if it needs a firmware update also check the connections if your unit has a hideaway module
Posted on Nov 07, 2008
I have 4 KX-TG2740 units, each with 2 lines. One unit does not ring for line 1. It says "Ringer Off line 1". I can't figure out how to correct. Thank you.
Press CONF/FUNCTION key, scroll to Ringer Setting by using the up or down arrow of the center navigator key, then press the right arrow. Press the right arrow again at Ringer Volume. Press the down arrow to select Line 1. Press the up or down arrow to choose the ringer volume you want. Press the right soft key SAVE, a confirmation beep will sound.
The ringer volume can also be set while a call is ringing in on the line. Make a call to Line 1 number, use up or down arrow key while phone is ringing to adjust volume of Line 1 ringer.
The following link is for the manual in pdf format.
http://service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
Jan 31, 2011 | Panasonic KX-TG2740 Cordless Phone
My tv is stuck in retail mode, how do i reset that?
Enter the OSD menu by pressing Menu on the remote or the TV. Press the down arrow to reach Installation (bottom of the list) and then press the right arrow to to enter this menu. Then navigate to Preferences (third in the list) and press the right arrow. Then navigate to Location and again use the right arrow to enter this item. Set the unit to Home instead of Shop. Press OK on the remote to save the setting. Then press Menu to exit the OSD.
If you are using the controls on the TV, use the Volume +/- buttons to navigate left or right in the menus. The Channel Up/Down buttons will let you navigate the vertical menus.
Once in the Home Location, you can adjust the color or brightness. From the Menu, choose TV settings and then Picture.
I hope this helps.
Dec 07, 2010 | Philips 50PFP5332D 50 in. Plasma...
How to print a usage page for HP color laserjet CP2025n
You can print usage page as follows via front control panel on the printer itself.
  1. Control-panel display: The display provides information about the product. Use the menus on the display to establish product settings.
  2. Back arrow ( ) button: Use this button for the following actions:
    • Exit the control-panel menus.
    • Scroll back to a previous menu in a submenu list.
    • Scroll back to a previous menu item in a submenu list (without saving changes to the menu item).
  3. Left arrow ( ) button: Use this button to navigate through the menus or to decrease a value that appears on the display.
  4. OK button: Press the OK button for the following actions:
    • Open the control-panel menus.
    • Open a submenu displayed on the control-panel display.
    • Select a menu item.
    • Clear some errors.
    • Begin a print job in response to a control-panel prompt (for example, when the message [OK] to print appears on the control-panel display).
  5. Right arrow ( ) button: Use this button to navigate through the menus or to increase a value that appears on the display.
  6. Cancel Job (X) button: Press this button to cancel a print job whenever the attention light is blinking or to exit the controlpanel
    menus.
Now follow these points to print th required page:
  1. Press OK to open the menus.
  2. Press the Left arrow ( ) or Right arrow ( ) button to navigate to Reports, and then press OK.
  3. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the reports, and then press
  4. OK to print a report.
  5. Press X to exit the menus.
The following information pages are available:
  • Demo page
  • Menu structure
  • Configuration page
  • Supplies status page
  • Network configuration page
  • Usage report
  • PCL font list
  • PS font list
  • PCL6 font list
  • Color usage report
  • Service report
  • Diagnostics report
SOURCE
Oct 25, 2010 | Computers & Internet
Can you set the Canon PIXMA MX 870 to print a confirmation page after every fax sent?
Yes. Press Setup and navigate (right/left arrows) to Device Settings. Then press OK. Next navigate to Fax Settings (up/down arrows) followed by OK. Select TX Report (again the up/down arrows followed by OK). Select the Print for each TX option (up/down arrows) and press OK again. Then press Fax to return to the standby mode.
I hope this helps.
Sep 28, 2010 | Office Equipment & Supplies
I recently noticed a message that said "drum end soon" on the screen portion of my printer. With that I went and replaced the drum and toner. The problem is this: The "drum end soon" message never quit...
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  • Press Menu on the Control Panel.
  • Press the Up or Down Arrow key to select Machine Info..
  • Press OK.
  • Press the Up or Down Arrow key to select Reset Menu.
  • Press OK.
  • Press the Up or Down Arrow key to select Drum.
  • Press OK.
  • Press 1 to reset the drum unit counter.
Thank you !!
Jun 09, 2010 | Brother MFC 7840W Printer
Updated drivers, mouse no longer works, windows xp
Please try to use keyboard to uninstall Driver Robot. Please press the winkey (key with Windows Sign on it), and goto Control Panel with arrow keys and press enter. Now using arrow keys goto Add Remove Programs and press enter. Now navigate to driver robot and use TAB key to select the remove or uninstall button. Please follow the on screen instructions.
I hope this will resolve your problem. Please do rate my solution.
Regards, Rashid
Oct 28, 2009 | Compaq Presario S6000CL (DT072A) PC...
Philips DVP3960 uncolck code
region-free hack?
I used the following and it worked fine for me on a recent purchase of a Philips DVP3960
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 1 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
Press the 9 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
Good luck
Feb 15, 2008 | Philips DVP3960
Added Avoidances
Go to setting and then Navigation and you should see the following
Dec 28, 2007 | Garmin StreetPilot C330 GPS Receiver
Pioneer AVIC-D3 Car DVD Player Logo
90 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
