Question about Sony Playstation 3 (PS3) Console
Cant get hdmi for ps3 to work on my jvc hd 52g887
Hooked up hdmi cord for ps3 cant seem to get anything to 52"jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Posted on Nov 07, 2008
I can't connect any sort of HDMI enabled device to my JVC HD-52G887 television. Does anyone know how to fix this?
Check to confirm that you are using the correct input source for where it is plugged in. ie HDMI 1 HDMI 2
If that doesn't work check that the cable is good and is seated properly on both ends.
Jun 10, 2015 | JVC Televison & Video
Can't get picture after hooking ps3 up to jbc hd-56g647 by HDMI cord
If it works on another TV, make sure the correct HDMI port is connected.
Jan 09, 2015 | JVC HD-56G647 Compatible TV Lamp
Is the JVC model HD-52G787 or HD-52G887 able to receive digital siginals without the use of converter box?
It doesn't look like it.
Have a look;
http://www.retrevo.com/pdf/391dj496/4/Quick+Setup#q=JVC+HD-52G887
Hope that helps.
Jan 05, 2011 | JVC Televison & Video
I bought a hdmi cord so my son can play ps3 we
Hi:
Check the video connector on the PS3 for a switch to switch from composit video to HD video.
Dec 26, 2009 | Vizio VW32L 32 in. LCD HDTV
HDMI broken on JVC HD-56G786 TV
have you ever went thru your hdmi setup procedure that jvc recommends?
Sep 07, 2009 | JVC HD-56G786 56" Rear Projection HDTV
My jvc tv model# HD-52G887
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Jun 19, 2009 | JVC HD-52G886 52" Rear Projection HDTV
My 52' HD television will not turn on, it is a JVC HD-52G887. The blue light comes on but there is no blinking red light. Please help
unplug the tv, then reinstall the bulb,if that doesnt work youll need a tech to help. (dont buy another jvc tv)
May 19, 2009 | JVC HD-52G886 52" Rear Projection HDTV
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Hd-52g887
How do you know the bulb is fine? Are the LEDs blinking together or alternating?
Apr 14, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Sony Playstation 3 (PS3) Console Logo
580 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
