Question about Dishwashers
Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
The dishes in the top rack of the dishwasher are coming out as clean as normal. The dishes in the bottom rack are not getting very clean at all. Dishes that have been pre-rinsed and scrubbed still have visible smears, streaks, and other dirt on them. We have jet-dry in the dispenser and ran a wash cycle with some vinegar as well. There are no unusual noises. The inside of the tub is nice and dry after the cycle is complete.
  • charlawrence Dec 08, 2008
    My lower arms seem to be working fine. I have run vinegar and CLR through the washer. I also notice that during the wash cycle, I can smell the heating element and when I open the door, it appears as if there is very mininimal water in the tub. This problem just started about 2 days ago and I have had the dishwasher for about 10 months.
  • 324 Answers
Check to make sure your lower spray arm openings are not blocked.
Posted on Nov 07, 2008
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher leaves upper rack dishes dirty. It's Whirlpool Quiet Partner II
Your water pressure is not high enough in the dishwasher to wash the dishes on the top rack. The most common reason is that the pump in your dishwasher cannot pump fast enough to keep the water pressure up. That is because the shaft that drives the pump impeller also drives the macerator cutter that grinds up bits of food fine enough for it to pass through the screen and out to the drain. Over time, small bits of bone, broken glass, eggshell, and other items that are too strong to be cut up by the cutter end up sitting in the area where it has to spin, and they prevent it from spinning fast enough to pump enough water to the top rack with any pressure. It is simple enough to repair. You need to take out the racks, remove the bottom arm and clean out the little macerator. Once that is done, it should work great again.
Feb 22, 2011 | Whirlpool 24 in. DU900PCD Built-in...
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
I have a whirlpool quiet partner II dishwasher. There is a gritty residue on the dishes in the top rack and on some of the silverware. Any suggestions on how to fix this?
Jan 16, 2010 | Whirlpool Dishwashers
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it:
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Apr 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
666 people viewed this question
Top Dishwashers Experts
