Question about Casio Exilim EX-S500 Digital Camera
Casio ex-s500 front facade around lens has come off
The metal ring around the lens on the front of our Casio ex-s500 has come off. Actually, there is an outer ring that sits upon some cosmetic metal that makes up the stylized front. It would appear by the look that it is a twist lock mechanism, but it does not rotate.
Could we be missing a part that holds the ring to the front?
My wife accidentally dropped ours and the ring popped off when it hit the floor. It does just twist back on. You just have to get it lined up just right and then it will essentially snap into place. If you don't get the ring lined up right though it will just conitinue to fall off. I've had focussing issues with mine ever since the ring came off though.
Posted on Nov 13, 2008
Casio EX-S500
That is what Casio calls a "lens error". It needs to be sent into repairs.
Jul 29, 2008 | Casio Exilim EX-S600 Digital Camera
Frame around lens fell off
Do you mean the focussing ring fell off?
It can be reglued with Superglue, but be very careful not to use the glue from the tube or you could get it everywhere. First focus the lens on infinity. This is the furthest back or most withdrawn position of the lens. The infinity marking on the ring will be beside the diamond or dot indicator. Put a little bit of Superglue onto the end of a matchstick, and then use the matchstick to put traces of the Superglue on the lens barrel, exactly where the ring will sit. carefully place the ring on its correct position on the lens barrel.
May 27, 2008 | Casio Exilim EX-S500 Digital Camera
Casio exilim EX-S500 overexpose
i have the same exact problem with mine. it's two and a half years old as well. i also noticed that if you try taking pictures in any of the best shot modes the pictures come out looking like paintings.
also, did you ever try cleaning the lens?
May 25, 2008 | Casio Exilim EX-S600 Digital Camera
Casio s500 digital camera
This error indicate that focusing ring got stuck or jammed due external shock, liquid, sand & dirt etc. enters the camera.
  • What you can try to do is spray some compressed air into the lens area to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Mar 18, 2008 | Casio Exilim EX-S500 Digital Camera
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-s500 overexpourse
Mar 12, 2008 | Casio Exilim EX-S500 Digital Camera
Casio ex-s500
they are on the front side once you remove the cover diconnect the ribbon cables and look at the bottom right hand corner and there is one of your clips. the other one is caddy corner to it top left of the lens. I fix them also.
Feb 08, 2008 | Casio Exilim EX-S500 Digital Camera
Casio ex-S500
Its a bad lens. send it in for repair or get one off ebay with a broke LCD lens should be ok .
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
Soft focus s500
It is a bad lens very common issue with casio send it in for repair or get one off ebay with a broke lcd lens might be sill ok.I fix these cams all the time with bad lenses.
Nov 08, 2007 | Casio Exilim EX-S500 Digital Camera
Casio EX-S500 Lens error. when i turn the camera on i get a grinding sound and the lens only comes out part of the way. from what i understand the gears in the lens must be stripped. does anyone have a...
Remove the Back and front covers, then use a small flathead screwdriver to release the 2 hinges that hole the lens assy down; then unlatch the 2 ribbons cables. Now you can install the new lens assy. If you're not going to use the "old lens assy, can I have it, please? Thanks.
Oct 25, 2007 | Casio Exilim EX-S500 Digital Camera
EX-S500 Casio Exilim - Lens does not full extend on camera so the picture is blurr
get the new ex-600s.. my 500s's lens wont come back in either.. i got the 2 year ultra warantee this time cause they're junk cameras but it's the best compact for about a year till it breaks
Nov 12, 2006 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
75 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
