Question about Bosch Exxcel KSR34423 Refrigerator
Loud click / tap noise every couple of hours or so
Ever since we bought the Bosch Exxcel refrigerator it has made a loud click or tap noise every two hours or so. What can this be?
  • fishypaul Jan 07, 2008
    click every 3sec and not working/not cooling or freezing
  • Anonymous May 03, 2009
    I have the same problem, it's a LG french door. Tapping noise every few hours? anyone got an answer?
    Problem Solver:
  • 5 Answers
Could be a start relay problem,type in google and search why is my computer clicking.30$ fix
Posted on Dec 12, 2007
  • 237 Answers
Check your owners manual for a list of common noises it should make to see if it's on that list. Does this have an icemaker? That time frame could be an ice maker valve turning on for a few seconds to fill the tray (or dumping ice).
Posted on Nov 09, 2006
2 Suggested Answers
  • 89 Answers
SOURCE: verr loud clicking noises every
Hi, I think there is a problem with the refrigerator's compressor,get it checked by an expert. Thanks, C Rahul
Posted on Jul 05, 2011
My Bosch Fridge makes a loud gurgling sound every twenty five minutes even after freezer fan &emotion were replaced.
It's a normal noise! When the liquid refrigerant becomes less pressurised, usually when the thermostat clicks off,, it still bubbles through the system until the pressure equalises.
Dec 17, 2014 | Bosch B22CS50SNS Side by Side Refrigerator
My bosch is making a loud noise
I would call bosch directly, they have ppl that can help over the phone with some things.... Bosch is hard to work on so if you need service I would go with who ever Bosch recemends..... ken
Sep 29, 2014 | Bosch Refrigerators
Verr loud clicking noises every couple of minutes in my bosch frost free fridge freeezer has done since I bought it 6 plus years ago
Jul 05, 2011 | Bosch Evolution® 500 B20CS50SNW Side by...
Intermittent loud cracking noise when running, otherwise performs ok
Does the loud cracking noise normally happen at night when its quiet.
Anyway whenever it happens it is most probably the automatic defrost heater kicking in and the noise you hear is ice melting.This could cut in every 12/14 hours depending on system and would normally run for about 15 mins.After this time the compressor should cut back in and the unit will run as normal.
Hope I helped.
May 13, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch dishwasher srs45e02. when I turn it on there is a loud growling noise for a while then it turns itself off. any ideas please. I think it could be the pump. thanks any help.
you could be correct as the proceedure for all dishwashers when started is a pumping phase to make sure no excess water is still in unit.. when finished water then flows in..
Dec 17, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch SHX4AP05UC Very LOUD!
This doesn't add up to what other owners say. Have yo contacted Bosch? Also, your output line may be entering your drain system in the wrong place causing the noise for that issue. Good luck. I am looking at the same machine for purchase......
Dec 16, 2009 | Bosch Dishwashers
Poping noise
if its a self-defrosting i would believe its doing its job just as intended,that is unless you have other issues such as cooling problems
Jul 19, 2009 | Whirlpool GS5SHAXN Side by Side...
Thundering noise coming from hot taps,bath,sink taps...
Sounds to me like you need to have a water hammer device installed into your plumbing, I have only run across this just once before, the noise is very loud and very bothersome, you will need to contact a plumber and have him install a water hammer device into your system, also vibration dampers would probably help as well, if your water lines are running through floor joists and touching them, hope that helps
Jan 18, 2009 | Bosch Exxcel KSR34423 Refrigerator
Ice maker bar sticking at bottom now a loud grinding noise
you can replace the whole ice make or remove the head and replace the cut off cam inside the ice make head..
hope it helps
Jun 20, 2008 | Frigidaire FRS26R4A Side by Side...
Very loud noise BUt washes fine
could be wheel on back of drum check its not loose , only way to get to filter is to remove the pump from filter assembly lay it on the soap draw side to get to it easier
Apr 04, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch Exxcel KSR34423 Refrigerator Logo
1,089 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Starnley Johnwells
Starnley Johnwells
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
