Question about GE Advantium 120 Convection/Microwave Oven
GE Microwave MODel JVM1540DM1WW
The vent fan blows air from out the side of the unit and the top. This is causing the cook tops (gas) to lose convection.
  • William Miller
    William Miller May 11, 2010
    Can you explain this in more detail?
    It sounds like there may be a leak or a clogged filter.
  • GE Master
  • 9,098 Answers
I would double check the owner;s manual and installation instructions.
You can download GE owner's manuals and installation instructions here.
Posted on Nov 21, 2008
  • ChrisBaker20 Nov 27, 2010
    If the unit is not vented to the outdoors, it will blow out of the vents of the top of the unit (top front). Check to make sure you have a vent duct that connects to the outdoors. If you do not have a vent duct that connects to the outdoors, you can have one installed. If you do have a vent that connects to outdoors, you will need to check the vent on the top of the microwave unit. (You will have to remove the microwave to check it.) There is a metal piece on the vent that switches to either blow air out to your vent duct, or blows through to the vents on the top front of the unit.
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
The vent fan does not draw air from stovetop
There is a wire mesh filter and a carbon filter on the under side of the unit. IF they are plugged then it wont draw air. The other issue is this unit has a dual option for installing the fan. One is to vent to the outside and the other is to vent to the inside, if the fan is not installed for the correct usage, you have no airflow either.
Oct 19, 2017 | GE JVM2070 Microwave Oven
My cooling fan will not engage when I turn on the microwave. I am manually turning on the fan at High to make sure the temperature doesn't overheat the appliance. Sometimes after I'm done cooking if I...
There are typically 2 fans in these units. The fan that cools the magnetron and then the vent fan that intakes from the top of your stove then vents the air out or away from the unit. Are the lights that shine on the top of the stove working?? Sometimes if a bulb blows violently it can blow a trace off of the back of the main circuit board and that trace may also supply power to the fan
Oct 21, 2017 | Magic Chef CMV1000B Microwave Oven
Keypad not working after boiling water below
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Otherwise, the keypad may be damaged or worn out, or control unit may be damaged.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
Your full model number would be one of these: JVM1540DM1BB JVM1540DM1CC JVM1540DM1WW JVM1540LM1CS JVM1540SM1SS
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 09, 2010 | GE JVM1540DM Microwave Oven
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
GE JVM1870 Spacemaker Microwave Fan Malfunctioning when Cooking
There are two different fans in this model, as with almost all over the range microwaves.
One is the hood vent exhaust fan, which you can turn on and off at will, and which should always be on when cooking on the stove top.
This fan does not automatically come on when you cook with the microwave.
The fan which should always be on (automatically) when you are microwaving is the internal magnetron cooling fan.
If the cooling fan fails, the magnetron can overheat and the thermal cutout (TCO) / thermostat will open, killing the power to the oven. Ideally, this protects the magnetron from being destroyed.
If the thermal device is a thermostat, it will reset when it cools down, and the oven will work.
If the thermal device is a true thermal fuse, it is a one-time device and if it blows, it will have to be replaced.
If your cooling fan is bad, it needs to be replaced before using the microwave.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 16, 2008 | GE JVM1870 Microwave Oven
Blower motor on above stove microwave not running
The dual fan in the back is the vent / exhaust / hood fa. It will run when you turn it on, or if the stove top gets too hot.
The other fan is the magnetron cooling fan, and it will only run when you are cooking. If it is not running, your magnetron can be destroyed.
You can download GE owner's manuals and installation instructions here. That may help you a lot.
Please reply back with more details if this is not yet a FixYa...
Aug 17, 2008 | Microwave Ovens
Partial venting
Are you running the vent fan whenever you cook on the stove top? You should.
And you should run it on high if you're having steam problems.
Otherwise, you'll need to do something like use a small counter top fan to help circulate the air better.
Please let us know if we can help further.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fan stopped working in JVM1533BD microwave
I assume you're talking about the hood fan which ventilates the cook top and blows air through the grille across the top. If so, it's okay to use the microwave with that not working, but if you boil something on the stove, an external fan is definitely needed to keep mositure from going up into the microwave controls. If the cooling fan INSIDE the microwave (behind the keypad) is not working, then you do NOT want to run it unit it is fixed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 06, 2007 | GE JVM1542 Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
605 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
