Question about Speed Queen AWS52NW Top Load Washer
Speed Queen Marathon Heavy Duty Top Load Washer Model: NA8831W33931
Started a load of laundry (it might have been too full)
I had already done about 7 loads that day with hot water
It fill just fine but when it tried to agitate, the washer switched off and when I opened the lid smoke came out. (It smelled electrical.)
I uplugged the waher.
Later I plugged it back in and I tried the spin cycle and it drained out the water from the load. I did not notice a smell.
I unplugged it again.
Do you have any idea what I might have done?
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Spots on white clothes
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
  • 172 Answers
SOURCE: 28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Posted on Oct 04, 2008
  • 1294 Answers
SOURCE: I am looking for a model number on a Speed Queen Marathon washer
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
Posted on Mar 06, 2009
  • 12 Answers
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Posted on Apr 09, 2009
mhamlin63
  • 138 Answers
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Posted on Jun 29, 2009
Speed queen Marathon top loading washer- Water leaks into drum when not in use??? Shut off valves in the basement.
The problem is the water inlet valve has failed. There is a video on checking this at www.appliancehelponline.com/servicemanual.html it's a different model but the testing procedure will be the same.
Mar 28, 2010 | Speed Queen AWS52NW Top Load Washer
Motor rund but drum dont spinon speed queen heavy duty washer
Fluid Drive clutch greasy or worn,
Pump blocked or drive belt too loose
Feb 23, 2010 | Speed Queen AWS75NW Top Load Washer
Jun 29, 2009 | Speed Queen AWS52NW Top Load Washer
  • Behind the door
Mar 06, 2009 | Washing Machines
Speed Queen AWS52NW Top Load Washer Logo
911 people viewed this question
Top Speed Queen Washing Machines Experts
Dan Webster
Dan Webster
Chris Hall
Chris Hall
Paul Bade
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
