Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Grinder not working
My grinder is not getting power 80% of the time so the grinder's motor is not turnig pouring clean water in stead of coffe. Some times it works but most times dont. The rectifier bridge(D1) that powers the grinder's motor is also not getting 110 VAC, in fact i have permanent 110VAC all the way to T5 and T6 on one leg but when you push the button ta make coffe T5 & T6 does not open to pass the 110vac to it's center leg which furture will supply D1 rectifier bridge with AC for grinder's motor. Any one? what can cause this?
  • 1,089 Answers
Hi
First off the grinder motors are 110V DC not AC. I would say that your problem is in the micro switch for the doser box under the solenoid. It sounds like it might be stuck closed and that would by pass the grinder saying the the doser box is full and don't run the grinder. You may just need a new micro switch which is specialized.
Posted on May 24, 2009
2 Suggested Answers
SOURCE: Seaco Royal grinder not working
This FixaYa site is the biggest scam ever, nobody ever answer to any qwestions, the existing qwestions are posted and answered by the same idiot logged in under a diferent name. i'm sory to say i payed $14.99 for live chat and nobody ever answered, after one hour of waiting like a fool my live chat sesion expierd so i e-mailed FixYa support about it but nobody ever answered. There is no refound also since you can't get nobody to talk to you. So don't pay here or you'l get scamed.
Posted on Nov 08, 2008
My coffe grinder worked only once. What to look for to fix it
Replace under warranty?
I like the open it up and see approach - just be methodical - confirm power to switch, switch function, interlock operation, motor function...
Jan 05, 2015 | Cuisinart Coffee Makers & Espresso...
Grinder blocked
One posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
Jun 04, 2010 | Saeco Royal Professional Espresso Machine
I am having problems putting the hopper back in the burr grinder
Sometimes my wife or I pull the hopper out before the grinder is totally stopped and then some coffe gets behind the hopper. Thre are a couple of small slots that hold the coffe and the hopper will not slide back all the way again...we then need to take a knife and clean everything out good before it will work again...
heatman101
May 02, 2010 | Solis Maestro Electric Burr Grinder
My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Jan 30, 2010 | Cuisinart (CCCCUISINART) Grinder
Nov 07, 2008 | Saeco Royal Digital Plus Coffee...
Sorry you not get any good answers here, i where her regulary before and answer questions, but now i´m on sick-list and have not access to computer regulary. After 1 December i will be online again.
Now to your problem, if the grinder not grind like it does before it can be the printed circuit card that has to be replaced.
Try to check the grinding engine to see if it looks ok, you can also try to measure the grinding engine.
Let me know if i can help you more.
Best regards
/Mirran
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
No coffee coming out of the machine!
First step, increase the grinder size. Note: only change grinder setting while the grinder is spinning. If that does not work, look into cleaning your brew group screens. The machine should have came with a key to remove the screen. If your machine as a preground option try making a preground coffee without inserting coffee to see if only water will come out. If water comes out then you know its your grinder. Usually too small of grinder sizes will stop water flow.
If you need a brew group key:
http://cerinicoffee.com/Saeco_Brew_Group_key.asp
Espresso machine Cleaning supplies:
http://cerinicoffee.com/Coffee_cleaning_supplies.asp
Dec 01, 2007 | Saeco Incanto Classic Espresso Machine
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
554 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
