Question about Sony KDF-E55A20 55 in. LCD Television
KDF55E2000 - Red band at top of Screen
Hello -
Today when I was watching tv I noticed a light red almost pinkish horizontal band for about the top 2 inches on my tv. It looks pink at the top and then yellowish on the bottom. The rest of the screen looks ok. Any ideas?
  • Anonymous Nov 24, 2008
    I have the same red band across the top an also a light blue across the bottom. My t.v. is a kdf42e2000 not even two years old.
  • 163 Answers
SOURCE: Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
ken@ikenfixit.com
Posted on Jan 22, 2008
geemarie
  • 876 Answers
SOURCE: Light red translucent stripe at top of screen
On your Remote
>menu
>parental controls,favs & setup
>system setup
>display
>centering
You can use this screen to move your picture up a bit and get rid of the line. If it doesnt work the first time, move it a little more. Good Luck!
Posted on Aug 03, 2008
mistersony
  • 320 Answers
SOURCE: Discoloration
I don't think you are posting about a LCD flat panel set, since replacing he lamp on these means replacing the panel.. If this is a rear projection set as I suspect it is, there are two likely causes.
1) Pull the lamp back out and clean the dispersion lens/UV filter immediately behind where the lamp goes. Clean it carefully, because it is easy to damage.
2) You have a bad optical block
Posted on Oct 19, 2008
mistersony
  • 320 Answers
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Posted on Oct 20, 2008
  • 10 Answers
SOURCE: white has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Posted on Aug 10, 2009
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Dark band lcd tv
Back-light fault. Contact any service technician. The panel might be taken out for repair. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
The light blinks red continuously on my kdf55e2000 sony tv
Hello, does it blink in a pattern (example:blink 4 times pause and repeat 4 time blink)? Please let me know. tks
Nov 01, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
We have Toshiba 42" Plasma TV about 4 yrs old. The past couple of weeks we've noticed that there is a horizontal rolling band of pinkish color (about 8-10" band.) We really notice it when there are people...
Im pretty sure its not the television. You are getting interference from either through your cable box or your electric in the house. Possible bad dimmer switch.
Dec 14, 2009 | Toshiba 50HP66 50 in. Plasma Television
T.V. screen is green with bright horizontal lights top to bottom
There are 2 possibilities of green screen in this model.
1- Driver circuit of green gun is defective. 2- Screen itself is defective.
Now I want to know, do you have TV repair experience and basic electronics knowledge to test and check above 2 sections in TV?
Jan 10, 2009 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Watching TV and top 1/3 screen ghosted by colors
on this type of tv each gun is controled by hor.and ver. chip together. it is on the board that controls the convergence of the tv. some manufactors have recalls on problems like this. i dont know if this one does but it may. you can check with mitsub. i do know that this part is about 250.00
Jan 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Red Convergence
http://schematicscom.blogspot.com/
http://homenol.blogspot.com/
Visit these sites. Convergence procedure of projection televisions are given in detail.
Mar 28, 2017 | Televison & Video
KV-32XBR250 Has about twenty Horizontal, Light Red bars aternating
your problem is called retrace lines it is due to 1 supply to red out put is absent 2 problem in red video output 3 loose contact in red output ckt 4 connector loose 5 crt base loose 6 circuit from red output of chroma ic to red video input 7 chroma ic defective regards
Sep 11, 2007 | Sony KV-32XBR250 TV
Sony KDF-E55A20 55 in. LCD Television Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
