Question about Vector Power On Board High Intensity Discharge Spotlight
Vec2705 polarization varification of recharge port
Hopefully this is an easy one, is tho positive the pole in the center, or the outer contact surface? Waiting in the dark for your reply.
Thank you.
J. Maas
Hello, and yes I'm still in need of a solution. Lost the power cord, have replaced it w/universal, need to know spec on polarity. Is the positive contact the center post inside the recharge port or is it the surrounding contact of the same location? New universal has polarity switch, capible of both options. Do NOT want to fry the unit.  Speaking of which mine appears different than the one you have pictured. Mine is YELLOW, very ylw, w/black rubber bottom with the added feature of a 260psi air compressor on board. Unit also provides a 12v power outlet(cigarret lighter varity) and one small LED light mounted forward, just above main spotlight. Dementions are 13.5L x 8.25H x 5W. Thanks for any help you may provide, and might I say just how impressed I am w/ your response time. Although at this time your premium service I must forego, I've bookmarked your site and "I shall return!"
Posted on Nov 07, 2008
HP pavilion dv2000 polarity
If you are referring to the polarity of the DC voltage at the plug-in tip of the charger, the center pin/socket is the positive, and the outer ring is the negative.
Dec 01, 2015 | HP Computers & Internet
I need to know the POLARITY of the AC adaptor to provide the correct setting using a universal adapter.
there is no polarity in ac current as ac means alternating current and that means alternating between positive to negative back to positive back to negative and so on
only dc ( direct current ) and the center pin of the plug is designated as the positive pole has polarity, the outer case being the negative
OR Are you asking the voltage of the ac adapter and the voltage of the dc output side of the adapter
Nov 26, 2015 | Office Equipment & Supplies
I want to buy a battery charger. Where do I purchase?
Hello
The external power adapter for your device is for [6VDC - 1 Ampere]. You can use any adapter with this capacity to charge the battery inside the your Philips Da1000. Brand is not matter, but the voltage and current is. Just check the DC socket polarity. It is the main thing that ahs to be checked. Some sets will have outer (+ve), and some others have (Outer (--ve). This will be marked at the DC in terminal of your radio. It is best to be the set in hand, when you go to buy a new one. This adapter can be bought from most of the electronic spare parts selling shops at your town. Philips has designated as [6V direct current, positive pole to current pin] as pin confuguration for the AC adapter. If so outer ring connection will be (--ve). Anyway, make sure about it before buying a new one. OK.
Aug 30, 2011 | Philips DA1000 FM Radio
Two pole polarized contacts, one is small, one is large, which one is the positive contact? Marine application. Watertight desk connections.
Hi!
The positive contact would be the small one. The large one is used for ground ALWAYS!
Hope this helps and happy boating!
Jul 10, 2011 | GPS
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
Need polarity chart for ac power adapter 12v 2amp
Almost without exception, the polarity of power packs is; the centre is positive (+) outside (-) In very rare cases the opposi=te is the case, but this means the outer contact is able to "short" on any metal it touches.
Mar 17, 2010 | Boston Acoustics BA745 Computer Speakers
Need to know the polarity of the power input plug Is it center + or - Compaq presario v5000
Normally all laptops' center pin is positive and the outer cylindrical shaped metal area is negative. What is your purpose to know it? Playing with adapter may make your system dead. Be carful.
Feb 17, 2010 | HP Compaq Presario V5000Z Notebook
Charging
The inside metal pin is Positive.
The outside 'shell' is Negative.
Sep 01, 2009 | Black & Decker VEC158BD V-3 Million Power...
Need the polarity of the adapter for polyview v17e moniter
i'm guessing you don't have the original adaptor to test it... sometimes polarity is printed onto the case where the adaptor plugs in... get out your magnafying glass to see it tho.
Jan 02, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
MISSING POWER SUPPLY
Normally, the polarity is molded next to the connecter hole; it may not be real easy to see.
If you have a digital multimeter with a 'diode' position, most devices have a diode internally installed to prevent damage in case of a bad substitution and the meter will show a value of somewhere between 500-800, typical would be in the mid-600s.
If you find that, then the meter is currently causing the internal protective diode to conduct as it would if the WRONG polarity would be applied and most meters will supply a positive voltage to the red lead for diode function.
Commonly, the center is the positive contact but this sure isn't certain.
May 27, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Vector Power On Board High Intensity Discharge Spotlight Logo
263 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
