Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV would not Turn On
The system would not come up when turned ON.
  • 4 more comments
  • eue1001 Nov 07, 2008
    Standby Light blinks 6 times when unit is turned On.
  • eue1001 Nov 10, 2008
    a Technician is underway to fix the problem.
  • nreynolds49 Nov 13, 2008
    My Sony Trinitron 36' will not turn on. The standby light blinks after turning it on, but there is no picture.
    Please help!
  • tman4032 Nov 28, 2008
    I have the same problem I turn it on and the screen won't come on. The light blinks six times. What do I do?
  • Amcdeid Nov 29, 2008
    I have the same problem. The standby light flashes 7 times. If its too expensive I would rather replace the set.
  • kmint Dec 18, 2008
    same problem here -- mine blinks 6 times. Then I turned it off / on again, it blinked 4 times....
    Any ideas how much to fix it?
  • 4,234 Answers
These sets have internal diagnostic capability and should cause the standby light to blink when it fails to start properly. Can you count the blinks and post that number here? That will indicate the problem circuit and allow us to give you some potential solutions.
Posted on Nov 07, 2008
65 inch mitsubishi model# 65736 green light blinking
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Sep 29, 2016 | Mitsubishi Televison & Video
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from
Jan 19, 2016 | RCA Audio Players & Recorders
I have a RCA sound system with an hdmi port to plug into TV but the sound system will not turn on the tv will but not the sound system is there a fuse in the sound system to make it turn on that may have...
So to clarify, the T.V. turns on but the system doesn't turn on with it? Most external sound systems have their own and separate power supply. You will need to turn it on as well as the T.V.,
Elisa Jed '
Apr 20, 2014 | Televison & Video
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Apr 28, 2011 | Bose 3·2·1 II System
V tech tv learning system will not turn on
this system is frustrating because if you don't do the steps in the right order it won't work. Start with the TV and Vsmile OFF.
step1) put the cartridge in and make sure it's all the way in
step 2) turn the TV on
step 3) turn the Vsmile on
If it still doesn't work you may have to take the batteries out, or unplug the adapter, whichever power source you are using, to clear it and then start the steps over. Good luck!
Nov 15, 2010 | Vtech V.Smile TV Learning System
Tv will not turn on
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like, to buy a whole rerfurbish power supply board for the replacement.
May 23, 2010 | Akai LCT3701AD 37 in. LCD Television
I currently have a DVD in and it won't eject. I have a Samsung HT-Q100 System
Turn off the DVD player completely. You MAY have to turn off the tv too. Let sit until you count to fifteen! Turn back on, tv first, then DVD player. You should be able to eject the disc then.
Jan 01, 2010 | Samsung HT-Q100 System
Flashing green light
Did you try this yet
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
I initially turned on ps3 system on tv. image
Turn off the system, Then when its in standby mode when the red light is on, press and hold the button to turn it on, Wait untill you hear 3 beeps then let go if the system turns off try it again its a master reset then just restore factory settings
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Am I forgetting something?
Your old TV took off the sound before the volume control and the new one takes it off after that control. Not much you can do without going in and doing some rewiring. You could use a VCR for your TV tuner source and then you would be able to turn down your TV sound and still get sound to your surround system. Good luck.
Feb 02, 2007 | Sony HTD-DW760 System
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
