Question about HP LaserJet 3015 All-In-One Printer
Streaking My HP LaserJet 3015 has white streaking when I copy a page, but not when I print from my computer. I used a laser printer page cleaner, but it did nothing. That is all I have attempted.
Were is the scanning glass bar on the HP3015 and how does one get to it?
Posted on Jul 03, 2008
    Problem Solver:
  • 14 Answers
Check the scanning glass bar. If you scanned something that had whiteout on it, a lot of times some of the whiteout will get on the glass and will cause streaks in the prints. Clean it with alcohol.
Posted on Jul 03, 2007
I have a xante 502 it has streaking on the top side of printing I printed each color and streaking is on each color with black the worst what part do I replace?
if you are familiar with ilumina menu search for the ID Test Pattern. Print test using 11 x 17 page.
On the copy you will see which of the drums need to replace, if the copy has vertical or horizontal lines on it the drum which ever color shows it has to be replace.
Jun 19, 2014 | Xante Ilumina® 502 Laser Printer
HP LaserJet P4515 Streaking
It is possible that the cleaning blade on your toner cartridge is malfunctioning. Try replacing it.If you can time it right,try shutting down printer in middle of print job when copy is between toner and fuser and see if the problem is before it reaches the fuser.
Apr 22, 2014 | Office Equipment & Supplies
I have an hp LaserJet 3015 PCL-6 all in one printer, copier & fax. When I use the copy function, there is a black streak running down the length of the copied paper. I tried replacing the toner...
Clean the thin glass strip that sits to the left of the flat bed glass.
That is the glass used when the ADF is being utilized.
There is dirt on it causing the black streak.
Oct 11, 2011 | HP LaserJet 3015 All-In-One Printer
Multifunction HPLASERJET 3015: when I start copying a document will always print a black vertical line on the right of the page
Advisable for users & tech guys: Lift document feeder unit clean "scan head" glass with glass cleaner, check..
Sep 24, 2011 | HP LaserJet 3015 All-In-One Printer
How do I remove white streak from copy when i use my 3015?
Most common cause of this issue is low toner. Best solution is to remove the toner cartridge and while keeping it mostly level, shake it from side to side to level out the toner. Then re-install and test. If this fixes your issue then just be aware that the toner cartridge is starting to get low on toner.
Now if the white streak is very fine and the above procedure does not work then it is most likely something stuck to the scanner glass. To test for this print out a report from the operation panel or if you have the machine connected to a PC print something from there. Are your print outs ok? If so it means that it is definately something on the scanner glass. To locate it and clean it just make a copy of something. Now take that copy with the blank line on it and place it in the feeder just as you did with the original. now wherever the blank streak is lined up on the machine is where the spot is going to be on the scanner glass. Just open the cover where the documents go in and look for the strip of glass that runs from side to side. Your copy passes over this glass when it is scanned. Where the blank line hits this glass is where the trouble spot is. Just clean the glass with a cloth that has some glass cleaner sprayed on it. This should resolve the problem.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | HP LaserJet 3015 All-In-One Printer
White line to left of every page that is printed/copied. HP LaserJet 3015
you have to clean or replace your scan unit, call the technician
Apr 07, 2010 | HP LaserJet 3015 All-In-One Printer
I have a HP laser 2600n and it is streaking magenta horizontally.
Sounds like the red cartridge was removed or tilted and leaked toner on the drum. Just do a self clean and it will clear up. It in the maintenance menu.
Mar 07, 2010 | HP Color LaserJet 2600n Printer
Color streaks on all pages hp laser 2840
the streaking is caused by a worn out or damaged transfer belt assemble. This is a user replaceable item just like toner. Office Depot or Staples can get one for you.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 30, 2009 | HP Color LaserJet 2600n Printer
Print page is streaking in the center of page
open the printer up , try cleaning the rollers with some alcohol. Possible some ink got stuck on the rollers at one point and when they heat up it streaks the page, other option is check your ink cartiridge that could be defective as well
Jul 01, 2009 | HP LaserJet 3015 All-In-One Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
HP LaserJet 3015 All-In-One Printer Logo
201 people viewed this question
Clive
Clive
