Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
No Internet light on DSL modem
When I went to the system trouble shooting site http://192.168.1.254/, it told me that it was unable to find an ATM circuit. The DSL light is on, at@t stated that the signal was turned on. They were unable to diagnose the problem. Their only solution was to send a tech next week. I have put filters on all my phone lines and tried turning off my modem and turning it back on again. Not sure what else to do.
  • nygaards3 Nov 07, 2008
    The internet light does flash sometimes.
  • Jim Oliver Nov 07, 2008
    I have the same problem with my Westell Versalink 327W modem..
    Genius:
  • 1,124 Answers
Try testing the line that goes to your dsl modem with a external phone.
If the internet light in your modem is not ON or RED that means that you have a problem on your phone line.
Posted on Nov 07, 2008
  • Pablo Csaky
    Pablo Csaky Nov 07, 2008
    or a failure on your dsl modem
  • Pablo Csaky
    The ethernet light must be on.
    The Activity light will start blinking when you use the internet (This is normal)
    To get access to your modem (default) you have to type this on your browser
    (the modem must be connected to your computer thru ethernet cable)
    http://192.168.1.1
2 Suggested Answers
eastpole
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
The power light stays red and does not pick up the DSL line. Then after a short while the modem shuts off without it being unplugged from the outlet.
Telephone your local ISP (Internet Service Provider). If they provided the DSL modem to you, they can trouble-shoot your problem, and, if necessary, ship you a replacement modem. If they cannot help you, it is time for you to find a different ISP that _can_ help you.
Jan 03, 2011 | AT&T High Speed DSL Modem
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Unable to connect to internet. Only two lights show -- power & dsl. When I called for help I was told I needed a new ethernet cable. Bought that & installed. Same problem -- only two light lit...
In all there should be lan led, dsl led, power led and internet led,
So if dsl and power led is glowing and others not?? than check the lan cable and even check the lan card of ur pc is it enabled or drivers are properly installed and same way try to check the modem configuration??
Sep 08, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
All lights are green on my DSL modem except the internet light which is solid red. I called AT&T for help ( My modem was a brand new combination router/modem from Netgear with wireless N) and after a...
If you have ATT DSL they should be supplying the DSl Modem. Unfortunately they supply Motorola 2210's, which systematically burn out due to overheating. The symptom is that the DSL blinnks, but the other lights to the right of that will not come on. That means it is sending requests to the network for service, but the receiving section is unable to receive the reply.
I am on my 3rd 2210 in 3 months. ATT do replace them free, but they really need to switch to a different manufacturer.
Aug 23, 2010 | Arris Netopia 2210 ADSL2+ Modem SinglePort...
My shared internet connection speed is very slow, please help.
Hi,you can check your exact internet speed with this http://www.ip-details.com/ site ,after that take a decision for your internet speed , here only i got my exact download and upload speed .
Mar 03, 2010 | Computers & Internet
I have the Zoom X6 (5590) DSL Modem, trouble using software
You may check the following:
1. Make sure to plug the power cube into a power strip or wall outlet and then plug the power cube's other end into the modem's power (PWR) jack.
2. You should only use the power cube with the Zoom X6. Other power cubes may damage your hardware.
3. Try another wall outlet.
4. Reset the modem. Use a paper clip and insert it into the RESET pinhole in the modem's back panel and press it 3 times. Then turn off the modem for a minute and turn it back on. Check if the power light will turn solid green.
5. Possible defective modem.
Hope this helps! Good luck!
Dec 12, 2009 | Zoom X6 Adsl Modem/router Rohs...
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Internet
Well, I understand that the modem is SS4100, which means ther are
5lights on it being, Power, Ethernet, DSL, Internet & Activity....
Note:The trouble shooting is done according to the Light Status on the modem.
1. No matter what the proble is, the first step is to Power Cycle the modem to eliminate the static on the modem(to switch it off and back on).
2. If the Power Light is anything other than a solid green, then the modem is fried(except the fact that the adapter is plugged and working).
3. If the Power is green and Ethernet is off, then check for the LAN cable at the back
of the computer if its connected to the modem.(It turns green if connected properly)
4. If the DSL light is anything other than solid green, then call up the ISP tech's to ask why the intenet is not working.
(make sure the DSL cable is plugged firmly onto the back of the modem and the wall jack)
5. If the Power, Ethernet and the DSL is green and the internet is not, the open up the Modem page(type 192.168.0.1 in the address bar and enter for the modem page), and cross-check for the username and the password. Save the changes and your internet is working!!!
6.  The Activity light usually blinks green and it does't have much to do with the troubleshooting.
The above are the basic troubleshooting steps.
Hope it solves your problem......
Dec 20, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Modem settings for Siemens SL2_141
First of all check whether dsl yellow light is on or not.
if it is not on then contact bsnl local branch.
otherwise
remove dsl line from modem.
Then
open internet explorer
type http://192.168.1.1
username= admin
password= admin
click WAN
edit pppoe 0_35_1
connection type=bridging
encapusulating =LLC/Snap-bridge
next
again next
save
save/reboot
close IExplorer
connect DSL line.
if its work plz reply me
findme_rohit@yahoo.co.in
Sep 14, 2008 | Computers & Internet
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
3,825 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
