Question about Canon imageRUNNER 210S Copier
Print network in canon imagerunner 400
Canon imagerunner 400 machine print test page not came, and waiting came some minutes and after jump copy mode.
what problem please kindly solution of my problem.
awaiting for your favourable reply
thanking you
  • 1 more comment
  • jegatheesh May 11, 2010
    Hi friend
    how u connect ur machine to pc
    thats networking caple or pcl cable
    how u install ur IR 400 mc
    if its ethernet cable check ur IP address
  • george eisener May 11, 2010
    how are you printing?
    have you tried again?
  • Anonymous Mar 28, 2014
    When I turn this machine on, it says waiting and never boots up.
E051
Posted on Nov 22, 2008
My canon imagerunner 6000 hangs on starting the machine. It just says wait.....
Most copiers and printers have a mode called power save mode. If the Machine is not in use it saves energy and powers down to a lower level. Once it receives a print job it takes a bit for it to warm up. It can take up to a couple minutes on some machines to do their self test while powering up. As long as it gets to the ready mode to unit is good. On some unit you can disable the power save mode or make the between going into power save mode longer.
Printer Repair Service in Miami and Fort Lauderdale FL
Jan 15, 2016 | Canon Office Equipment & Supplies
Hello, and thanks for any help you can provide. My Canon ImageRunner C5180 sometimes hangs on "Waiting to Print ..." That is, someone sends a print job, "Waiting to print..." begins to...
i think that the problem with hanging hides in your PC network and incompatibility of some files with printer driver version or something like this. Try to find from which PC do you have problems and look for software reasons. This machine is to big to make little problems...
Can you COPY when the machine trys to print? If you can, I think that everything with CANON is OK.
If you type the IP address of Canon in some of your internet browsers you will get instant access to WEB MONITOR and there must be error log somewhere.
Good luck
pifonski
Mar 02, 2011 | Canon imageRUNNER C5180 Color Copier
PCL Start Page Print print every time when power on zerox machine
You need to set the start-up options to not print the this page. You have posted in the Canon ImageRunner section but say it is a xerox.....
Feb 23, 2011 | Canon imageRUNNER 400 Printer
We have Xerox Machine Canon IR C5800. the problem is while copying after more than 200 or 500 copies the machine copying is slow down i.e., may be 45 copies per minute. why? can u please sugest...
This model is 58 pages / minute in B&W mode, but If you print color prints it takes longer because the machine is built that way. Because the machine only have one drum unit instead of four, all four colors have to share the same drum unit, you can probably hear it when you take a color copy *chunk chunk chunk*. That is the sound of all the four developing assemblys spinning on a giant "revolver like" construction. And when taking color copies the machine have to calibrate it's colors now and then to ensure good color quality. So, once again, the machine is slower when taking color copies, nad faster with B&W.
Dec 18, 2010 | Canon imageRUNNER C5800 Copier
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on emma.servis@gmail.com with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
I have a canon imagerunner 4080. how do it get screen where i can have the machine to test print solid color?
There is not a feature like that in user mode. If it exists, it would be in service mode. I do not recommend going into service mode as you can brick your copier.
If you can print to it, make a print job of a solid color using your PC. Otherwise make a copy of colored construction paper.
If you have a Fiery imagePASS controller, you can print color calibration pages. On the touchscreen use the -> arrow in the upper right and then select the printer tab. press the printer status button, press functions. use the menu from there to print calibration or configuration pages.
May 06, 2009 | Office Equipment & Supplies
Won't Print
Dear;
start by removing the driver rom your PC, then unplug the machine from the PC.
if your are using USB cable,when you replug, the PC will ask toinstall driver, then you do.
if it is network, install driver and then link up te machine and try toprint.
It must work.
Jun 25, 2008 | Canon ImageRUNNER 1670F Copier
Canon imageRUNNER 210S Copier Logo
122 people viewed this question
old marine
old marine
