Question about Dacor ECS136 Epicure Stainless Steel Electric Single Oven
Possessed Oven This Dacor oven is not my main oven and has only been used 5 or 6 times since it was installed 2½ years. Almost from the beginning I noticed that the oven light would come on for no apparent reason. I would turn it off, and it would be fine for a few days/weeks until it happened again. Eventually, the light would blink off and on, and I would punch buttons until it stopped. Then the fan came on and would not turn off. I think there were a couple of other issues that I can't remember, but I eventually had to turn it off at the circuit breaker. I had two opinions from qualified repairmen (one of whom actually called Dacor for a solution), and both men said I should replace the ERC. I finally did that (to the tune of well over $400), and it worked fine........ for two days. Then the light started blinking again. It is currently turned off at the circuit breaker. I have read on other websites that others have had this same problem and, as in my case, Dacor wasn't helpful at all. I have not, however, read a solutions to my problem. I don't want to keep pouring money into this already expensive oven. Can anyone help?
  • 3 more comments
  • Mar Purcell Oct 08, 2007
    I was the original poster of this Possessed Oven problem. After having the ERC replaced (as mentioned above), I had the membrane switch replaced. I haven't had a problem since. (I'm keeping my fingers crossed!)
    And yes, it was a fortune to repair. Way over $600 for both. Dacor needs to quit ignoring this problem and take care of its customers! I won't buy this brand again.
  • 2schnauzer Nov 15, 2007
    Hello possessed oven and others. If you got rid of your possessed oven, I think we bought it! Everything is exactly as you posted in yours. We thought we were losing our minds. We will explore the membrane fix and see if that does it. Will post follow up. Also would appreciate any other suggestions. I, like mjpig rarely use this oven. It was suppose to be the state of the art when we purchased it 6 years ago....stay tuned for more ghostly follow up. 2schnauzer
  • sailrsam Feb 29, 2008
    Same problem with Dacor Model PCS230. Oven lights blink continuously and the control relay sounds like it's chatter itself to death.
    Slight pressure on the membrane switch (light icon) and the blinking stops. Release pressure the light stays off for a few seconds then starts flashing again. No error codes. The problem seems to be in the membrane board itself that is cemented to the glass front panel. Replacement membrane board is $128.00, now on order.
  • Anonymous May 01, 2008
    I have had exactly the same problem with a blinking light that will not go off without turning off the curcuit breaker.
  • Axiedog May 22, 2008
    I am very disappointed to report that my Dacor PCS130 wall oven has failed me. I have an all Dacor kitchen - 2 wall ovens, a microwave (whose display is also a problem as part of the numbers don't show up anymore.) and a gas cooktop. I even recommended a Dacor oven to a friend and she bought one!! Bad move on my part as they have had trouble also :(
    My display is beeping and code F1. I tried resetting the breaker - no luck. Now I understand I need to replace the touchpad assembly for a mere $750 (service call included.) This unit isn't even 6 years old and doesn't get much use as I have two ovens!
    Do I have to replace the whole assembly? Will Dacor cover any of the expense?
I found a new touch panel (or membrane switch pad) for < $166 at http://www.myapplianceparts.com/ . The person on the phone at this company was very pleasant and immediatley confirmed that they had 10 of these in stock. This suggests to me that more than a few of these have gone bad. Luckily, they are very simple to replace if you are willing to turn a few screws and carefully pull of the electrical connectors. I dissasembled mine in 20 minutes, got the part number (#62682B for my ECS130), and found best price in 20 minutes.
Posted on Oct 08, 2007
  • 175 Answers
I have usually seen 2 problems causing the light to come on and off. 1: the door hinges have been sligtly bent and need to be replaced (the door doesn't push the light switch all the way in and the light can come on and off) or 2: The touch pad on these tend to go bad and make intermittent connections for no apparent reason. This is called the membrane switch. It is mounted to the front panel from behind, and you will have to remove the erc you installed to get it out. I belive this mebrane switch pad is much cheaper than the erc, but I'm not sure of that. The touch pad is also miore likely to cause other problems, wheras the hinge problem is only going to cause the light to come on sometimes. Hope this helps!
Posted on Oct 22, 2006
How to turn fan to oven
First of all, here is the main DACOR ONLINE SUPPORT page for your model:
http://www.dacor.com/Our-Products/Wall-Ovens-Single/Distinctive-Single-Wall-Oven.aspx
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.dacor.com/WorkArea/showcontent.aspx?id=18137
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions on how to use the various cooking modes of your oven including the convection fan feature.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 13, 2011 | Dacor DO130S Oven
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Apr 09, 2008 | Dacor ECS230 Epicure Electric Double Oven
Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
ECS130 - Possessed Oven
The fix is replacing the mebrane panel. Recent poster advised they where able to get Dacor to send a new panel and they would install (it's not difficult). I bought one online for around $175 and installed myself. Do a search for details.
May 23, 2007 | Dacor ECS130 Epicure Electric Single Oven
Oven enamel chipping
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Jan 12, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor ECS136 Epicure Stainless Steel Electric Single Oven Logo
382 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
