Question about JVC KD-AVX33 Car DVD Player
Automatic screen change for rear camera view
When i place my car in reverse the camera comes on but i have to press the menu button manually to change modes in order to view it on the monitor. How can i get this unit to change the monitor view mode automatic to camera, when put in reverse and back to previous when out of reverse. My reverse wire from the unit is connected to the power wire of the camera and to my reverse light wire.Like i said the camera comes on but the screen does not change.
  • 1 more comment
  • lotusv8tt Nov 07, 2008
    kd-adv38
    kd-adv38
    Nothing in the manual other than the rev. wire.
    President:
  • 624 Answers
This may be the way it was designed to operate. Have you checked the owners manual to see if there are instructions for making this automatic change?
If you need an owners manual let me know and I will send a link for a free one.
Posted on Nov 07, 2008
    President:
  • 2,712 Answers
What is the make and model please?
My screen has caution screen image may appear reversed how do I fix it
It's showing the rear camera display, but you don't have a camera connected.
Press the "home" button, then press the rear camera icon on the display. This will stop the display from defaulting to the rear camera input. Then go into the settings menu, find the rear camera setting and turn off the camera. That should disable the camera icon on the home menu.
Aug 28, 2015 | Car Audio & Video
Have a d8o take a picture does not show on back screen
If you wish to manually view all the photos you've taken, press the play button, it is located near the screen on the back with a triangle logo.
If you wish to automatically view photos after they've been taken, press the menu button, go to the sub menu with the pencil icon, and turn "Image review" to on.
If you wish to view the images on the back screen as you take them, this is not possible with the D80. You have to use the viewfinder.
Feb 12, 2011 | Nikon D80 Digital Camera with 18-135mm...
My pioneer double din screen says ''Caution, screen image may appear reversed''...how can i solve this problem?
As you know, you can use this DVD AV Receiver with a rear view camera. And also it can be installed to switch automatically from the video to rear view image when the gear shift of the car is moved to Reverse position.
But it is important to use a camera which outputs mirror reversed images.
Otherwise the screen image may appear reversed. And this means that you will see the rear view reversed in the monitor. And that may cause accicent and injury.
To solve this problem, first check your rear camera whether it has the capability to output mirror reversed images.
If it is, then check the wire connections of the rear camera using the operation manual or ask a technician.
Also check the settings of camera polarity if it is set properly or not in the system menu when connecting the rear view camera.
You can download the operation manual (pdf file) by clicking here.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | Pioneer AVH-P4000DVD Monitor
The camera turns on when the power button is pushed the start up screen comes up then the camera shuts off. Battery is fine and can view photos on card. Help!
If you mean you no longer see anything on the screen. Try hitting the picture taking button slightly and the rear view screen should come on again. This is a energy saving setting and can be changed in the menu setup.
Jul 14, 2009 | Casio EXILIM EX-Z1000 Digital Camera
What does the green/white wire connect to on my jensen vm9312hd? Says it is reverse +
Rear View Camera Input: The VM9313 features a composite video input and a green/white wire lead attached to the harness for connection of a rear view camera. If a rear-view video camera is connected, the unit is on, and the TFT monitor is retracted inside the unit, the TFT monitor automatically moves into the viewing position and Camera modes is selected upon shifting into Reverse gear. When shifting into Drive gear, the TFT monitor is retracted back inside the unit. If the monitor is already in a viewing position and in display mode, the monitor automatically switches to Camera mode upon shifting into Reverse. When the reverse driving stops, the monitor returns to its original input display mode. You can choose for the monitor to display a Mirror mode image or a Normal mode image from the rear-view camera.
Jun 21, 2009 | Jensen's VM9312 Car DVD Player
No video screen
If you can touch the screen and get the menu, then after 15 seconds or so, it goes back to the 'images may appear reversed' message, here is what you need to do....
1) Touch the screen to get menu
2) Touch the "Rear View" button (lower left of screen)
3) It should beep, but not change from menu view.
IF it changes instantly to the 'images may appear reversed' screen, repeat steps 1, 2, 3.
This should fix your issue.
Mar 12, 2009 | Pioneer AVH-P4000DVD Monitor
My screen
It is telling you that, depending on the rear-view camera that is attached, the image MAY appear reversed. If the unit is going into this screen on it's own, go to the main menu screen where you would choose DVD, RADIO, AUX, etc... and press Rear View. It should beep (but not change). That is it.
Jan 20, 2009 | Pioneer AVH-P4000DVD Monitor
I cannot get the LCD view screen to work ?
There should be a menu button on the camera. if there is, go into the settings and turn the LCD Screen back on. (Actually if you press the menu button on the camera, you should see the menu on the LCD screen.) There is an option to turn off the screen to save battery life.
Dec 17, 2008 | Nikon D70s Digital Camera
Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
OR
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Jango
Dec 11, 2007 | Kenwood DDX7019 6.95 in. Car Monitor
JVC KD-AVX33 Car DVD Player Logo
164 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
