Question about Canon PIXMA MP830 All-In-One InkJet Printer
Sponge strip came out!
The sponge strip came out. I kept on having error codes and finally my problem popped out. It's about 7 inches long and has notches in it.
How do I replace it??
  • Teresa Thrush Nov 07, 2008
    Error codes were 5100 and 5700. Paper was getting jammed.
    Printer works just as well without this strip. I'm not going to take it apart because it is a multipass.
    I do appreciate the response on this matter.
  • 286 Answers
That's funny. That strip should not be able to give you an error code.. It's just used to soak up ink when the print head prints with no paper in the unit (during a jam or misfeed). You'll likely have to take the unit apart.
It goes on the "Platten", which is the flat piece directly under the path the head travels across the printer. If this is a multipass with a flatbed scanner, it will be quite a pain to take apart, and I wouldn't recommend anyone do it who's not adept at disassembly and reassembly.
The strip will just press into a similarly shaped slot that goes across the platten.
The machine should work OK without the strip installed. You should take a note of the error code and find out what it means (call or e-mail either Canon or your local Canon service centre). Try checking your owners manual, or try going to www.canon.com and down-loading the owners manual, it may list the error. Could be as simple as a full ink absorber...
Posted on Nov 07, 2008
"Waste Ink Level Full" appears on my printer,
With this type of Printer you will need to contact Canon and find a near by printer repair center. They should be able to replace the waste ink absorber kit in your printer in about an hours time provided they have the kit on-hand. I would not try to replace it youself due to that fact that theres many parts inside and some printers have timing wheeling inside them.
Canon Customer Care Center at 1-800-OK-CANON
Besst of luck...
Nov 22, 2010 | Canon MultiPASS MP370 All-In-One InkJet...
Received "Service Required - Contact Epson" on my R380 printer. How can I remove this error or correct it? Thank You, Rene
Well Rene its a sort of con trick by epson to make money from service. Get the ink tanks to pop out to the centre ( 0on startup of the run and take a torch and look back at the home base of the cassettes you should see a black square that is a sponge. carefully pick this up with tweezers or somthing that wont damage it.
Use blotting or kitchen paper and press the sponge in it to remove excess ink. wile the tray out and replace the sponge. Sometimes a small amount of like warm water and a few drops of bleach will dissolve the ink on the sponge.
Replace the sponge carefully ensuring it sits flat. repower the machine and it should now work OK You have just saved yourself $120 dollar service fee
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Epson Stylus R380 InkJet Photo Printer
MP830 has a 6A00 code
The 6A00 is a Canon generic code for paper path jam and seems to be a very common problem with these printers. Click Here to read some resolutions to this issue that may or may not work for you.
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Ip4300 canon pixma
I have the Canon Pixma iP4000R printer. I had an error code of a600 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Nov 19, 2008 | Canon PIXMA iP4000R InkJet Printer
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Had paper jam. removed paper, now getting 11 flashes, but cannot clear error as per manual instructions. getting service error 6A00.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it(purge unit). The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
CANON MP830 PRINTER ERROR CODE 6A00
6A00 is a purge unit fault, if you have have a years canon warrenty i would call them and get a engineer out to investergate the fault, If not strip machine and and see if the purge unit is moving back and forward. it could be that the carriage unit is stuck on the purge and the carriage unit cant move.
Hope this helps
Mar 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All in One - A600 error
Here’s what I found.
There is a sponge to the right as stated but right next to that is a white plastic arm assembly with a spring attached to it.
It was the white plastic assembly arm that was stuck and not fully retracted. I tried to move it back and forth and then (pingk) it fully retracted. I powered on the printer leaving the ink caddy to the left and as it was cycling I could see the plastic arm was covered with dried ink. I powered it off and moved the ink caddie to the left again and powered it on again. As it cycled I pulled the power plug leaving the assembly fully exposed. Grabbed some paper towel and put some alcohol on it and cleaned the dried ink off as best I could. I left the caddie to the left as I powered it up to see the assembly work
The printer is working again
Jan 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
139 people viewed this question
old marine
old marine
