Question about RCA Personal MP3/CD Player
Audio output from my TV
I have both audio input and output on my TV, how would I hook up a set of wire headphones to my TV? I have my VCR, and DVD player hooked up as well, is this going to be a problem?
Take a red and white audio rca cable and cut off one end of the jacks. on the end you cut, solder a headphone output plug on. can also solder on the lines of a pair of headphones (where you've cut off the 1/8 in jack) directly to the rcv jacks.
Posted on Jun 18, 2009
How do I hook up dvd to tv
If your TV has the standard analog audio and video inputs (yellow, red and white jacks) or for better image (S-Video rounded 4 pin jack or component video red, blue and green jacks), you'll only need the corresponding cables, and also your TV could have HDMI port (digital video and audio signals), you should use this connection, all depends of what type of outputs provide your DVD/VCR, in the case your TV set doesn't has any of mentioned inputs, you still could use the antenna input and connect its matching output from DVD/VCR , tuned at VHF channel 3 or 4.
Feb 12, 2011 | LG RC897T DVD Recorder/VCR Combo
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I connect A STB to VCR to TV
connect the RCA jacks, audio ( red and white) and video(yellow) to the input on the vcr then hook another set of RCA jacks from the output of the vcr into the tv audio and video inputs
and thats it!
electech
Oct 20, 2008 | Televison & Video
I want to record a dvd from my tv/dvd/vcr combo to an external vcr. i'm not trying to break any laws, it's only for my babygirls personal enjoyment. please tell me how the wires should be
as long as you're not breaking any laws you can connect the video/audio output of your combo unit to the video/audio input of your vcr using audio/video rca cables where the yellow plug goes to the video input/output and the red plug to the right audio and the white to the left audio input/output.
Oct 16, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
I dont know how to hook up my rca receiver to my dvd player and my tv and vcr so i can have it all running i dont know what wires go where
first check your receiver if it has inputs for all those gadgets you wanted connected. in your input function selector see if there are options for your dvd, tv, vcr. if it does have all those inputs then just connect all the audio output left/right rca jacks of your gadgets to each input function of your receiver. your VCR though is different, you have to connect the receiver input to vcr output. the vcr record goes to the vcr input connections. your TV, if it has got any audio out then connect to the audio in function of your receiver.
May 03, 2008 | Audio Players & Recorders
I am trying to hook up my tv to my receiver, I have a dvd vcr combo,and cable box
Audio: There should be a set of audio outputs on your TV. Connect those to the AUX inputs of your receiver. When you turn on your receiver, set it to AUX. Set your TV volume to approx 1/3 and adjust the volume on your receiver. There's probably a menu section on the TV to turn off your TV speakers so the sound will only come from your receiver.
DVD/VCR (I'll call it DVD from this point forward): Connect the video (yellow) output from the DVD to the "video input" on the back of the TV. Connect the audio out on the DVD player (red) to the red audio input on the back of the TV, then do the same with the other audio (white). When you want to use your DVD player, you'll select "input 1" as the input on the TV.
Cable: Your cable box probably has numerous output types. I have the cable box hooked up to both the DVD player AND to the TV; one output type going to the DVD player and another output type going to the TV. I like to use the HDMI output from the cable box to the TV, and the composite video from the cable box to the DVD.
Hope this helps. Let me know if you need more info.
Mar 18, 2008 | Televison & Video
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Recording from vhs to dvd with a dvr
You can get a standard audio/video cable from any Radio Shack or audio equipment store. It will most likely come as a single 3-part cable with a yellow (video), white (audio left), and red (audio right) set of connectors on each end. Most equipment that's not too old will have matching color-coded sockets marked input/output. Simply plug the video/audio cable into the vcr output and the other end into the dvr input. then connect a second cord from the vcr output to the tv input. Then with everything turned you will be seeing the final signal on the tv and you can start the dvr when you are ready to start recording.
Nov 22, 2007 | Cyberhome DVR 1600 DVD Recorder
Sanyo TV
If I understand your posting/description right, you have:
1, a Sanyo TV with only 1 video input;
2. you have a DVD player with only video output; and
3. you have a VCR (which I will assume to be with both video input and output).
Your query, if I may clarify, is how to hook them up so that you need not connect/disconnect any video cable when you want to switch video source from either DVD or VCR.
If that is what you want, then connect:
a. audio/video OUT of your DVD to audio/video IN of the VCR;
b. audio/video OUT of your VCR to audio/video IN of the TV.
The above described connection would allow you to:
i. watch DVD movies on your TV (your VCR must be powered ON and set to Video INput, your TV must be powered ON & set to Video INput);
ii. watch tape movies from your VCR without disconnecting/connecting cables.
Additionally, this arrangement would allow you to record DVD movies in your VCR. Further, connecting your cable/aerial to the RF INput of your VCR would allow you to do the same with a TV/Cable program.
Incidentally, if one of your units (TV, VCR, DVD) would only have a single audio input, it is still possible since some models uses the white audio RCA connector as either left or mono, the red is right. You can also use a 2 female RCA to 1 RCA male adapter as shown below to joint the red/white audio.
Hope this be of some idea/help. Pls post back how things turned out or should you require additional information.
Good luck and kind regards.
Nov 19, 2007 | Sanyo DS32224 TV
355 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
