Question about Thermador PRDS484GGUS Gas Kitchen Range
Thermador oven doors
My oven doors keep falling off. It's costing me a fortune to call a technician. Please tell me how to reinstall them. Thanks
  • patsyjane Dec 29, 2007
    My convection oven door fell off just bumping into it, how do I fix it. I can't get a repair tech out here for five days, which is ridiculous!
I would call Thermador directly to see if they can help you. My oven door didn't have the proper restrainers, it cost 159 dollars for a repair person, and the proper restrainers. It's expensive, but it's a good deal over the life of the oven. Thermador has their own repair team. But if they can't send someone, then see if you can get the parts yourself.
They have told me that now, it shouldn't fall off. Unfortunately, when people take the door off, they often lose the pins that keep the hinges open (for installation) they also lose the retainers.
Posted on Jan 14, 2009
After I cleaned my ovens the top one doesn't heat anymore. I was told that the circuit fuse button has to be reset. We can't locate it. Can you please help? The model umber is: Thermador SCD302TP
Welcome to FixYa.
To address your post, looking for an over-temp cut-out tripped. Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the lower door ( just below upper door) next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...as shown here,
If indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Other than that if you call in a pro, I'd suggest you be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Hope that answers your question and gets you back up and operating. Good luck.
Regards,
Macmarkus :)
May 29, 2011 | Thermador SC302T Electric Double Oven
I have a Thermador smw272 oven that the lower oven door will not close all the way and the light stays on. I have replaced the hinges and roller assemblies three times and I still have the same problem. I...
is the door switch bad?when you open the door all the way if it is at a 90 degree angle the hinges are good also i just looked your model number up and it says the hinges are no longer available part 14-38-045-01
Nov 14, 2017 | Thermador SMW272 Electric Double Oven
Is there any way to tighten this door up ,the one i have comes down just a little and the light comes on
Hello, Welcome to FixYa. Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges. Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Recommendation: Adjust the door box hinge per instructions below.
1. Pull the oven away from the wall about 12".
2. Remove the hinge box cover plates.
3. Remove the vertical side trim piece. It covers one of the screws that must be loosened.
4. Loosen the 4 screws that secure the hinge box.
5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws.
See fig below
6. Re-install the hinge box covers & side trims.
7. Re-install and secure the oven.
That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately.
Let me know if you require further assistance or if indeed this solved your problem.
Thank you for choosing FixYa today and good luck going forward.
Regards,
Macmarkus :)
Jan 06, 2011 | Thermador SEC271BS Stainless Steel Single...
Hello, I have a SC272T double oven. Both of the oven doors have sprung and sometimes the light inside will come on. I have looked at the use manual and do not see any instructions on how to correct this....
Hello, Welcome to FixYa. Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges. Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer. If you can bare with me for a couple or three hours until I arrive home ( I presently am away and only have my iphone as a means to communicate and all my Thermador files on my PC ) I will post the suggested temporary "fix". Regards, Macmarkus :)
Oct 25, 2010 | Thermador SC302T Electric Double Oven
The icemaker is not making ice.
dear sir/madam
i think it,s low gas problem so please contect to your service technician refill refrigerant in your freezer .
hope anser the question
thank you
please vote!
Jul 16, 2010 | Thermador T30BR70FSE Freezer
Door won't stay closed
I just had this issue happen to me last week.. fortunately I was standing in my kitchen when it happened... I heard a snap and then a piece fall down the inside of either the door or the front key panel.. I'm assuming this controlled the door locking/oven turning on safety mechanism. The inside light wont go off and it won't turn on to cook.. I am trying to figure out if it's worth paying to fix or just replace the whole unit!? Anyone know if this is fixable by oneself rather than spend a bunch of money on a service technician??
May 28, 2010 | Sharp R-1610 Microwave Oven
Removing the door from a thermador oven CT130
Usually you will find a hole in each hinge to hold the hinge open when removing the door.
It is impossible to fight the door hinge springs and remove or install the door.
One opens the door and puts a nail through the hole to keep the hinge open for each hinge.
Feb 20, 2010 | Thermador Ovens
Probe light stays on so I can't cook
After calling an authorized technician and the thermador support line, neither of which solved my problem, i was told a HARD RESET of the PROBE is all that is required. This problem originally occurred on my Thermador double oven after a power outage and rendered my oven unusable b/c the probe light would not go off -- even though i had never used the probe!
To hard reset the PROBE, turn off the oven at the breaker box, plug in the probe for 1 minute and remove it, then turn the power back on at breaker box, and probe light goes off!! Also, since i didn't have the original probe and to buy a new one would be $80, I borrowed a friend's Thermador probe (different model but it still worked). It cost me $85 for the service visit, 2 weeks of nonoperational oven, and about 5 hours time -- hence the reason i am making this post. It is a golden trick!!
What did NOT work -- turning off power to house again for 15 minutes to reset the OVEN, and disconnecting the probe wires from control panel so probe isn't recognized.
Nov 26, 2009 | Thermador SEC272BPSS Electric Double Oven
The upper oven door dosen't shut tight.
Door not closing properly is normally due to weak door hinges.
Normal procedure is to replace both the hinges.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Thermador SC302T Electric Double Oven
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Thermador PRDS484GGUS Gas Kitchen Range Logo
476 people viewed this question
Top Thermador Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
