Question about Mitsubishi WS-55807 TV
Mitsubishi WS55807 Converge prob.
Hello, I have a convergence prob. I will work great for about the first couple of minutes when I turn it on then pop out. I have a service manual but still don't know where to find the converge chips to check the soder or pins. Could you show me where to look or explain where or what to look for. Thanks Nate
    Scholar:
  • 167 Answers
Hello yes i can tell you where to look . take front of the set off and there's a cover with screw's holdng it on . take it off . and your convergence board in the front of the set.'GOOD LUCK"
Posted on Nov 22, 2008
  • MICHAEL WALLACE
    MICHAEL WALLACE Nov 25, 2008
    HELLO . UNPLUG THE SET AND TAKE OFF THE BACK . AND WHAT YOUR LOOKING FOR IS TWO OR THREE LARGE SILVER HEAT SENK'S THAT IS WHERE YOU WILL FIND YOUR IC CHIP'S. THEY WILL HAVE LETTER'S & NUMBER'S ON THEM .!! LIKE STK-393-110 . OR SOME LIIKE THAT.!!! THEY WILL START WITH STK- FOR SURE.!!! THEY WILL BE HELD ON BUY SCREW'S TO THE LARGE SILVER HEAT SINK'S. AND WILL BE SOLDER TO THE BOTTEM OF THE BOARD ALSO. !!! "GOOD LUCK"
Hello, I purchased and installed one
You will need a original remote to make the changes to the multipoint and single crosshatches. Do a google search for remote controls to find the Philips remote.
Jun 04, 2011 | Philips 51PP9100D 51 in. Television
The colors red blue shake back and forth on the ws55807 mitsubish
maybe you need to goto menu and auto converge colours..
try degauss feature if avail..
Is it a projection tv if so you may need a flyback anode block for R,B guns.
Dec 16, 2009 | Mitsubishi WS-55807 TV
Ws55807
hi
your convergence circuit has started giving trouble .... normal thing after a few years running for projection televisions ...... could be that the convergence IC's are getting too hot (two big IC's on a heast sink bearing an STK number on it) or that you have some loose soldering that needs to be resoldered on them.... worth the check
or have your power supply circuit board checked, if nothing seems wrong trouble leads to your horizontal deflection circuit board.
regards
May 28, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Mits 55908 Convergence problem
Good Day, John;
It sounds like the Convergence IC's have poor solder connections, by re-soldering the convergence output IC's should solve your problem. The IC's are large and mounted to large silver "heat sink" with STK 392 # on them. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Auto Converge
If the message "sensor is unresponsive" crops up then the problem is definitely electronic and lies somewhere in a loop that starts near the tube base, goes to the main board and back to the tube base. However, you can try to do a manual converge by adjusting the ring permanent magnets on the neck of the tube (right behind the scanning coils) while something is being displayed. Normally these magnets are secured with a clear glue to minimize drift. Use a heat gun to soften the glue and then turn the ring magnets around until you are happy with the picture. As you know, this part of the TV has some pretty dangerous high voltages so try to keep your left hand in your back pocket while doing these adjustments with your right. Good luck.
Jan 18, 2008 | RCA HD56W58 56" TV
Three colours don't converge
Shrink, the convergence circuit needs to be repaired, Until someone gets in there and takes a few measurements it`s hard to say what the cost will be, may just need to be re-soldered, good luck, BMW Rider
Dec 18, 2007 | RCA P46810LV 46" Rear Projection...
Mitsubishi ws55807
I had this problem and corrected it by resoldering all 36 pins of the 2 convergence IC's. Biggest problem was getting the circuit board out far enough to prop it up and get underneath and get at the solder connections, required unplugging a few cables, 3 screws holding it in. Works great now, I used to fix it by taking the back off and banging on the Heat Sinks which house the IC's, I could tell then that it reacted like cold solder joints. I decided after a field service guy charged us 95.00 for a service call and quoted 650.00 for a repair. Hope this helps someone.
Nov 05, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55807 TV Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
