Question about Kodak Dock Series 3 Laser Photo Printer
Kodak dock series 3 printer
It only prints half the picture, the other side is blank.
  • 4 more comments
  • Hap Pleasant
    Hap Pleasant Dec 10, 2008
    Same problem. Only prints half the picture. Doesn't matter whether from PC or camera.
  • pbhanna Dec 15, 2008
    The printer only prints half the photo and I see the split cam, but I'm having difficulty accessing the cam to make the repair.
  • bascochick Dec 22, 2008
    Printer prints the top half of the picture. Not sure where the cam is to fix or what I"m looking at when I look in the printer. Need more specific instructions. thanks
  • apes1003 Dec 28, 2008
    same problem.. prints only half of photo.
  • Anonymous Jan 20, 2009
    What are you showing here in your pictures? if I succeed in taking apart my printer as you indicated, then what is the red circled area signify? What am I supposed to do? Thanks for your efforts, but I'm not following at all... if you can clarify further.
  • Anonymous Jan 31, 2009
    If the little white piece is stuck up, push it down.
  • 3 Answers
Sorry for the delay hope this is not too late. I was able to fix mine without removing the cam or the rod.kodak dock series 3 printer - c0b30ab.jpg7d99504.jpg
Posted on Jan 11, 2009
  • 1 more comment
  • Hap Pleasant
    Hap Pleasant Feb 14, 2009
    The little white piece in the red circle was cracked and would rotate on the metal bar. Rotate the white piece so that it is touching the metal frame below it. Like the larger white piece at the other end of the rod. Then super glue it in place.
  • Hap Pleasant
    When the metal bar rotates the white piece in the red circle should press down the spring loaded piece underneath. The larger white piece on the other end of the rod pushes down on the same spring loaded piece on that end. The spring loaded part must be pressed down against the paper for it to print.
  • Hap Pleasant
    super glue it to the rod. NOT the piece below it.
Printing Issue
It has dust or built-up goo on the feed switch. Try some canned air
Jun 11, 2010 | Kodak EasyShare Printer Dock Series 3
I see a number of entries with same problem. It
Yeah You may call kodak and send it for repair 1 800 235 6325., Unfortunately all the printer dock series is already discontinue., Or may be you can try to purchase a All In One printer of kodak that you can used to print your picture using your camera.
Nov 08, 2009 | Kodak EasyShare Printer Dock Series 3
Kodak Easyshare Printer dock series 3 not printing full picture
throw out your printer and buy another brand. if you call18002356325 the call goes to manila and chances are you will be talking to some one who only speaks partial english and knows nothing about kodak products but will read to you from these internet instuctions that you just read !!! kodak has become a very anti-american company in so many ways!!!
Aug 04, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Printer only prints on half the paper. any ideas
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Aug 04, 2009 | Kodak EasyShare Printer Dock Series 3
Kodak EASYSHARE Printer Dock
Well it's not looking to pomising by reading all of the other people who are having the same problem. But could you please tell me how to fix my printer in is only printing half of my pictures no matter how many times i reprint them and it also doesn't pick up the printing paper very well i have to help it along. So if you could PLEASE tell me how to fix this problem on my own it would be greatly appreciated. Please respond As Soon As Possible Please and Thank You. I have the Kodak Easy Share Printer Dock Series 3.
Patricia Davis
Nov 03, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Image prints on one side paper,kodak printer dock plus I have a printer dock that only prints on the bottom half of the photo paper. This dock is for a C533 Didgetal camara. Please help.
did you try to change the orientation to landscape or portrait? you can also check the printer properties and make sure that you have the right size paper selected
Aug 20, 2008 | Kodak Dock Series 3 Laser Photo Printer
If the boundary between the blank half and the printed half is a sharp line, a wire to the print head may be broken or disconnected. If the boundary is irregular (wanders up and down an 1/8 inch or so), the problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Jun 27, 2008 | Kodak EASYSHARE CD33 & Printer Dock Series...
Kodak Dock Series 3 Laser Photo Printer Logo
201 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
