Question about Amana Kitchen Ranges
Pot boiled over on amana flat top stove and spilled onto temp controls, now every time stove is turned on it makes loud pop "noise" and trips breaker
    President:
  • Amana Master
  • 2,651 Answers
Ouch!!!! leave it off, your gonna need to replace 1 or more of the burner switches,, hte unit will need to be dissambled to figure whigh ones are burnt and shorting unit out. id leave the breakers off for now
Posted on Nov 07, 2008
Amana counter top gas stove when plugged in start making clicking noise and you can smell gas .
on most, your push down and turn to hi to open gas valve and turn on piezio to light burner. it sounds like you have a knob already turned on . the control under the knob may need replacing. kinda an easy replacement if you get new part. check out repairclinic.com for video(maybe) but for parts for sure. be careful. gas is explosive.
Mar 16, 2015 | Amana Cooktops
Whats a proper finish
Best finish I could think of would be something by Rustoleum. They make a lot of "paints" designed for higher temp uses such as stoves and BBQ's, just be VERY CAREFUL that what you decide to use is designed for your application so you don't cause a fire. In some cases, cleaning the stove with vinegar can help this problem, but it's most likely your pots/pans that need a good steel wool scrubbing. Lol.
Aug 21, 2014 | Ovens
Why is the head not getting steam and its making a knocking noise it didnt come with instructions
The knocking noise is actually the water boiling to produce steam.
No different from a pot boiling on the stove. The only difference being the noise is dampened in open environment in the pot, while in the vacuum its a small closed environment with plastic which enhances the noise. There also could some hard water debris within the vacuum chamber which pounces around during the boiling process, such as the same when a water heater becomes old and hasn't been drained. Hard water causes calcium deposits which in turn causes knocking noises in a water heater.
May 10, 2014 | Vacuums
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Loud popping noise?
its just the unit in defrost mode,the popping sound is water hitting the defrost heater and boiling away,no need to worry
May 24, 2010 | Magic Chef CTF2125 Top Freezer...
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Stove top burners on glass stove seem to have a governor on them
My initial attempt at solving the problem was to contact the GE customer service phone line.  When I explained the problem, the representative had no clue how to solve it, and referred me to the service organization.  The representative at the service organization was equally clueless, and suggested scheduling a service call at $100 plus parts and labor.
This is all quite disappointing; these customer and service representatives obviously have no training in solving the simplest of problems.  This is okay if GE's goal is to maximize service revenue.  But, I can tell you I would be very unhappy to have a technician visit my house, for $100, only to be told I was using a pot or a pan that was designed incorrectly for a glass cook top.
I solved the problem by going to the web site www.geappliances.com, opening the user manual, and looking under trouble shooting.  The first problem mentioned is exactly as described above.  The problem is inappropriate cooking appliances.  It is not possible to transfer heat efficiently if the pot you're using has a rim or lip on the bottom.  That is, the pot must sit flat on the glass cook-top, it cannot be raised off the cooking surface by a lip that elevated the pot from the surface.  These pots are designed to be used with gas flames, not a glass cook top.
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
Thermostat
It should open when it gets up to the opening temperature. Better way to test it is to put the water in the pot, hot from the tap, and put it on the stove. Put a thermometer in there too so you can monitor the temp. Drop in the thermostat, then heat the water on the stove. When it opens, note the temperature that the opening occurs at - then you can see if it's opening at the correct temperature. If you put it in boiling water, it'll open - but you won't know if it opened at the right temp.
Aug 17, 2008 | 2000 Volkswagen Golf
Kitchen Ranges Logo
153 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
