Question about Kenmore Elite 45986 Front Load Washer
He3t front load
Goes through the cycles gets to 2 minutes left in cycle time sometimes it takes 40 minuters to finish any suggestions
I have a he3t front load washer that when it gets to two minutes left sometimes seems to take forever to finish we do use he detergent and i cleaned out the water pump what a mess of things i found in there a couple baby socks 8 hair elastics some loose change what was left of a pen ,and the remnants of a dollar bill is there any solution as to why it takes longer at the end or is this a normal thing? thanks for your input
Posted on Nov 07, 2008
We do use he detergent might there be anything else we should try?
    Sergeant:
    Champion:
  • 324 Answers
He soap?
SOURCE:
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Why does my Kenmore HE3t front load washer always take more time to finish then what it says on the timer?
Check the filters in both ends of the hoses. If they are clogged, it will throw the timer off. If it figures on 2 minutes to fill but it actually takes 6 or 7 minutes, the timer won't be accurate.
Jan 20, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 2plus wont finish cycle
I'm not saying you don't have a problem. But just to be clear. You do understand that the last minutes on these machines can vary. The machine senses certain conditions in clothing, water discharge, etc. So sometimes the "1 min left" indication can stretch into many minutes. In theory, at least, it's possible your machine just needs to be left alone until it finishes whatever it's doing. However, one would think that any issues not resolved in 10 - 20 min are an indication of a problem. So i guess that's my next question, did you wait long enough? Keep in mind i am not a kenmore expert.
Jan 06, 2013 | Kenmore HE2 Plus Front Load Washer
My front loading Kenmore is stopping in the middle of its cycle.
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 29, 2009 | Kenmore Washing Machines
Jumps time on timed cycles- for example: High dry is 40 minutes time goes down to 36 minutes and then is jumps down to 23 minutes. Once it goes down some it might jump back up during the 20's then it goes...
Replace the timer, this is very easy. Un plug, remove access panel in the back and un plug the timer. This will be connected right behind the knob. It will be screwed down in front as well. Call your local dealership and get replacement part.
Jul 26, 2009 | Whirlpool WFW9200S Front Load Washer
When the timer gets down to 1 minute left and the machine is on the spin cycle, it takes another 10-20 minutes to finish the cycle. The total 40 min. cycle takes over an hour to complete. Does anyone know...
The timer is only an estimate. pull the botttom cover of the front of the machine. There is a cleanout on the water pump, if its clogged it could be the cause of your timer taking so long
Jun 11, 2009 | Whirlpool GHW9100L Front Load Washer
Washer has timing issue, says it will wash for 45 minutes and wash for 1 hour and 15 minutes. The cycle says 50 minutes but it ends up taking 75 minutes.
This is really not uncommon. The more and more sophistocated the machines become, the more small decisions they make on their own. I have seen a one hour load take up to 2.5 hours.
If a load is off balanced, it will change the time. If the spin cycle doesn't spin enough water out, it will increase the time, and may still be too wet. (In that case you need to clean out the lint/drain trap.)
If you really want more control and quicker washes, there will be a setting like "Quick wash " or "Fast wash." Theis setting is quite basic and does exactly what you tell it to do, and you can always add and extra rinse, or higher speed cycles.
Kenmores and GEs are the highest reported rate of longer times. Relax. The more you add, ie, delicate, two rinses, light spin, medium dry, the longer it will take. It's just trying to do its job! :)
Sirwriter
May 29, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Wash cycle taking way too long, like 90+ minutes
You timer is bad and needs to be replaced. Your problem is a common error and is something a lot of people on here run into. You can go to repairclinic.com and get this looked at
May 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
115 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
