No picture, and TV shuts as sson as I power on the from the remote.
Error code is 66 when i press the Menu and Input together for 6 sec.
Any help FAST would be apprecaited.. 2 yr old tv..
Thanks
CD
Hello Getoxygen,
This sounds like a DM problem. To repair this you will have to replace 4 or 7 capacitors (1000uf 35v).
Here are the instructions. Depending on your set this may differ a bit, but the central theme is getting the DM free to be worked on.
This was taken from a TV repair site used by TV technicians.
STEP 1) The DM Module loose. But itcan't be rotate out because of the upper plastic guide.
STEP2) How the DM Module is rotated out of the TV case. Allow thewires
entering the DM Module to be an axis point of the rotation.That way they barely move and don't get snagged or stretched.
STEP3) The DM Module out and the side cover ofMitsubishi ED-52631 does not turn on - 0c96755.jpegousing removed.
STEP 4) My setup to do the soldering work.
STEP 6) The daughter board unscrewed and flippedover where you will be soldering.
STEP 7) The UpperPlastic Guide that must be removed to rotate the DM MoMitsubishi ED-52631 does not turn on - 726c802.jpegtheTV set.
STEP 8) Get this wooden horizonMitsubishi ED-52631 does not turn on - 2a80392.jpegt (4screws) and getting the upper plastic guide out becomes easy.
STEP9) Helpful Hint about the wooden shelf and the platic guide that bothneed to be removed.
I hope this helps
Thank you,
