FixYa.com
Tags:
Jensen VM9510 Car DVD Player
Screen sometimes doent come out
posted by c_dub86 on Oct 15, 2006
when i push for my scrren to fold out sometimes it comes out about 3 inches and stop and is very slow.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 10, 2007
Helpful (85)
Noggin
Rank:Guru Guru
Rating: 87%, 1359 votes
here is the link for the manual if you need it - ask again if you don't find what you need.
http://audiovox.com/manuals/owners/VM951...
Hope this helps :)
Comment by Noggin, posted on Mar 11, 2007
Sorry was a bad link should be:
http://www.audiovox.com/
Click on Jensen, select multimedia, then select "older models" and half way down you will find the link to the manual.
After a bit of research, it sounds like there are two possibilities for your problem - low voltage to the unit as a whole - think if the sometimes when it is slow to open is when you have the volume turned up - maybe the amplifier is drawing too much current for the circuit.
If you are comfortable using a multimeter, identify the power terminals on the supply plug using the installation manual at the link above, then check the no-load voltage - if it is low (less than 12.8 volts) then suspect either the car battery or the connection/cabling/fuse housing to the player.
Second possibility is that the screen ejection motor has failed, which is rare - check to hear if there are any gear grinding noises, however quiet when you try and extend or retract the screen, or any sound of vibration which may indicate a motor problem. These motors are probably not too expensive, but fitting them would probably be a job for a professional.
Hope this helps more :)
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Car Video Players problems?
gears on radio
my screen on my jensen vm9510... Answer This...
repair dvd player dual audio
when dvd and cd are inserted... Answer This...
phase linear uv8
turn on vehicle the volumn is... Answer This...
Jensen vm 9412
I just bought a jensen vm9412... Answer This...
vm9411 no disk reading
when i try to put a cd in the... Answer This...
Repair Service
Find Car Video Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
