I have about 40 papers jammed in my printer how do i remove the stack of papers
Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
High speed 250mm/s Easy loading
en.sprinter.com.cn
Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
ø Remove printer paper from its original packaging. Insert all unused paper into a large, resealable bag. Store the bag with the unused paper on a hard, flat surface away from extremes of heat and humidity to prevent curling, bending, ripping and wrinkles which can cause paper jams.
?? Remove only the amount of paper you need for a particular job from the resealable bag. Tap the paper stack on a hard flat surface to align the edges. Check the paper for rips, curls, wrinkles or bent edges. Remove and discard any unsatisfactory pages.
?? Insure all paper in the stack is the same size and type. Insure only paper types recommended for the HP All-in-One printer is being used. Recommended paper types can be found online at www.hp.com/support/inkjet_media.
?? Insure the HP Officejet All-in-one printer is not currently servicing a print job. Remove any original papers from the copier glass.
?? Insert the stack of paper into the input tray, short edge forward. Slide the stack forward until it stops. Do not force the stack beyond its initial stopping point.
?? Slide the paper width guide inward until the paper is held snugly in the input tray, but not so tightly that it bends the paper. Insure the stack of paper does not extend
?? Observe the printer during operation. Promptly remove printed pages from the output tray.
Follow the below steps to clear the paper jam
Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
Try printing another document.
-To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
-For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
-Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
