Air conditioner not working
The thermestat comes on and the outside compressor comes on but no air is coming out of any of the air ducts.
  • jburrell13 Nov 07, 2008
    Yes. The blowers are coming on. Just no air coming out of the vents.
Is the bolwers coming on?
Posted on Nov 07, 2008
Hi I have lg ducted type air co works fine on cold air but when switched to hot air will not work outside compressor does not come on
Outside temperature too warm to allow heat to come on. It would rapidly overheat the compressor.
Jul 01, 2014 | LG Heating & Cooling
Compressor won't come on I want to by pass thermostat
First check power or (high voltage) to outside unit if good make sure you have thermostat voltage or (low voltage) to the outside unit.
Feb 09, 2014 | Fujitsu 24C1 Air Conditioner
Cool air not coming out if air conditioner but all else works. Fan on outside equip works , air through ducts. Thermometer temp stays same. Water comes out of drip pipes .
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 05, 2011 | Carrier Heating & Cooling
The unit outside is making a humming/ buzzing noise. the air coming out of the ducts are blowing warm.
It sounds like you have a compressor that died... you could check the capacitor and replace it to make sure it is not a simple fix...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Weather King 10AJA3601AH Air Conditioner
My a/c unit does comes on but it only warm air not
Make sure the outside unit is running, compressor and fan. Sometimes it is hard to hear the compressor over the fan. If the outside unit is not working check circuit breakers first. Set thermostat to call for a/c and make sure the contactor in the outside unit pulls in. If it does check capacitor for whatever is not running. If everything seems to be running fine hold your hand above the fan outside. The air coming from it should be hotter than the outdoor air. If it isn't get the refrigerant charge checked.
Jun 29, 2010 | Goodman GPC1342H21A Air Conditioner
The heat from my aircondition is soo intence that my room becomes hot rather than cold air
you need to direct the hot air coming out of the unit out of the room and the cool air into the room. You need to run a duct or tube from the condenser side to outside. Otherwise it is just recycling the air and adding heat from the compressor.
Jul 18, 2009 | Danby DPAC7599 Air Conditioner
After a cooling cycle, when the thermostat call for more cooling, it take up to 5 minutes after the air handler starts for the compressor motor to restart. The top fan operates on the outside unit, but...
No, this cycle cannot be shortened due to the simple fact that this feature is in place to protect your system. Even if it could be, I wouldn't recommend it.
Mat
Jul 17, 2009 | Coleman Heating & Cooling
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
No air is coming through air ducts
filter could be stopped up on return air or coil frozen due to low charge
May 16, 2009 | Dometic Rooftop RV Air Conditioner
AC Compressor running outside but no air coming out of inside vents.
Can you say, WOw, Icould've had a v-8 moment! I think you answered your own question or you are not far from the answer. (let me direct you, either the thermostat or the little door on the duct going to your room! Thank-you-very-much!
Aug 01, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
