Question about Toshiba 50HX81 50" Rear Projection Television
Tv remote problem
My tv remote dropped into a bowl of salt water. i grabbed it out right away, but it is not working. does anyone know if i can dry it out or is it ruined forever?
  • michyboolina Nov 07, 2008
    thank you for your help. that was my thought, but it helps tohear it from a second mind.
If you rinsed it in fresh water immediately after the drop then maybe it will work again. You would need to replace the batteries.The prospects are, however, not good. Best to to get a new one.
Posted on Nov 07, 2008
I have one maxwest cellphone it's damaged by water, can it fix it?
Open the phone and remove the battery. Dab all internal surfaces with paper towel to remove as much moister as possible. Then use a hair dryer on medium heat to gently dry the phone completely. Make sure the battery is dry as well. Leave the phone open for a further half hour after drying and then put the battery back in and close the case. Switch on the phone, good luck.
Dec 30, 2014 | Cell Phones
Will SD card still work after dropping camera into salt water
If it wasn't in salt water for very long and you rinsed it in fresh water and then let it dry thoroughly, then yes, the card should still work. However, once you download the pictures from it, I'd consider throwing the card away.
Jun 01, 2012 | Canon Cameras
Water in camera wont turn on
If the camera went into the water and was pulled out nearly as fast as it went in, you may have got it out before water bathed the interior workings of the camera and lens.
Place the affected parts in a cloth bag - a pillow case will work nicely. Gate a large bowl and fill it with uncooked rice. Place the pillowcase with the camera into the bowl and completely cover with the rice so that there's at least an inch or two surrounding it. Place the bowl & camera in a dry location for 24 - 48 hours.
The dry, uncooked rice acts as a desiccant and will wick water and moisture out of the camera. The longer the camera was underwater, the less likely this method will work. If the camera fell into seawater or other saltwater solution, this will probably not work - or not work for very long. This is because salt is a corrosive. After the water is evaporated away, the trace amounts of minerals and in this case, large amount of salt, are left behind as deposits. The mineral deposits will not usually affect electronics - but can cause sticking or rubbing of close tolerance mechanical moving parts like those found in cameras and lenses. The salt on the other hand, is much more sinister. It will slowly eat the fine copper conductors on printed circuit boards, etc. and eventually cause the camera to fail.
I hope this helps & good luck!
Jan 10, 2012 | Canon EOS 600D Rebel T3i Digital Camera
My camera was dropped into salt water can it be fixed ?
Yep just cover it in dry rice in a bag overnight.
Jan 05, 2012 | Cameras
Hi my Samsung ES67 was working perfectly until I accidently dropped it into water! Ive dried it out and re charged it but it appears to have died! Is there any solution for this problem?
What kind of water...fresh or salt? How did you dry it out? The proper method is to bury it in a bowl of dry rice for a week. Did you try to turn it on too soon? If so, you could have caused a short circuit.
Jul 18, 2011 | Cameras
My CHAD remote was dropped in water. What are the chances that it will it still work if I dry it out?
if it is fresh water it has a very good chance of working again
remove batteries and leave it to dry for a few days before trying to put batteries back in and using
good luck!!
Mar 29, 2011 | Onkyo CHAD LCD Touchscreen Remote Control
Took the Canon Power Shot on a fishing charter at Coasta Rico. Camera was dampened in a bag with a wave of salt water. Not drenched but dampened. Took batteries out and dried camera for 7 days and still...
Saltwater? I don't think you're going to revive this camera. If it were fresh water - you'd have a fighting chance - but salt water is highly corrosive and is a much better electrical conductor than fresh water. Even if you managed to get the camera work right after it got wet - chances are the salt would eventually "work its magic" and corrode metal circuits inside the camera and cause it to fail - much the way salt "eats cars" in areas that roads are treated with salt in winter to control ice.
If you ever have a water problem with something not designed to get wet, place the item in a bowl of uncooked rice. Cover completely and let it sit a day or two. The dry rice will wick away water and moisture on and inside the device. If doused in salt water, the water will be absorbed - but salt deposits are left behind, as salt can not be evaporated.
I know it wasn't what you wanted to hear... good luck.
Mar 28, 2011 | Canon PowerShot SX20 IS Digital Camera
It was dropped in ocean more than a week ago . Now not turning on. What can be done to fix it?
Even if you dried it properly (burying it in a bowl of dry rice for a week before even trying to turn it on), salt water is very corrosive and continues to do damage for weeks and months. It also dries to a salty film on the lens elements. Dropping a camera into salt water is usually a death sentence for a camera. Even if you could find someone willing to repair it, the cost would be astronomical since everything except the case would have to be replaced.
Dec 18, 2010 | Canon PowerShot A560 Digital Camera
Sony Trintron KV32Fs12
Hope the advice given helped you. If you have any questions, feel free to get back to me here.
regards
Graeme
Mar 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My phone in salt water.
To anyone who drops their phone in salt water. Get the battery out immediately. When you get home or sooner if you can put the phone in something that will allow fresh water to immerse it entirely. Keep water running in the container for about 3 days continually flushing the phone. Now take all of the water out and fill the container with 99% Isopropyl Alcohol. Let the phone dry out for at least 2-weeks before trying a fully charged battery in it and turn it on. Should work and you have just saved yourself buying a new one. Then don't leave it in your pocket when you go to the beach, drop it in a Ferry Salt Water Toilet, etc., where it it is immersed in salt water. If it is most cell phone providers will refuse to even look at it from their tech depts. A Radio Tech/Inspector in Canada.
Dec 22, 2006 | Motorola Mobility V600
Toshiba 50HX81 50" Rear Projection Television Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
