Question about Samsung Yepp YH-J70 Digital Media Player
Error message When i switch on the player it gives me the following error message - "Device cannot HDD initialize", and then will not switch off or go to the menu, the error message just remains on the screen. Does this mean that my players hard drive is damaged, and if so is said damage repairable?
  • 3 more comments
  • shivram Dec 02, 2007
    I am receiving the same error Device cannot HDD initialize. I have a Samsung YH-J70. I tried opening the device, removing the battery and reinstalling it but the error stil remains. There is some talk in some forums about connecting the HDD to the motherboard. How do I check this in yh-j70? I have not used the device roughly and have not even dropped it once so there is no way the HDD can be damaged. Can anyone help?
    Rgds
    Shivram.
  • josuegneiss Dec 24, 2007
    yes, i have the same problem but i live in Peru . PLease answer me.
  • weskander Sep 23, 2008
    Same problem here. HDD not accessible, either via booting the device or through connecting to my computer.
    Is it possible to replace the hard drive? and how?
  • keith2000 Sep 23, 2008
    MY Samsung Player also Says Device Can,t HDD initialize. I have taken battey out and tried to reset it . My computer does not reconise it. When i1st turn it on i get a few seconds of noises from hard drive
    Regards Keith
  • Anonymous Oct 20, 2008
    I have the same problem, can anyone tell me how this can be solved?
    Regards
    Jeroen
    Problem Solver:
  • 18 Answers
The message "Device cannot HDD initialize" is usually a sign that the hard drive has failed. The sole solution is to install a new hard drive; the one installed in most YH-J70s is a Toshiba MK2004GAL. I have heard unconfirmed suggestions that a Compact Flash card can be installed in place of the hard drive and that it plugs in but I have not tried this.
@auntieannie2: replacement batteries are easy to find in the UK at least - try Googling for "samsung yh-j70 battery pack"
Posted on Nov 21, 2008
    Problem Solver:
  • 5 Answers
Did you try pushing the reset button and/or reinstalling the software? sometimes that helps. Also, I have a question for you: I am thinking of replacing the battery on my yh-j70, as it is getting weak, was it easy for you to open the player and can you then simply pull out the battery or do you have to solder? Would you happen to know where batteries can be bought for this unit? Thank you
Posted on May 22, 2008
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
LG 42 LCD TV HDD initialization in progress message
Change the hdd or remove it then connect it to PC and do for it format , it will work .
Jul 06, 2010 | LG Electronics 42 in. LCD Tv
"ATA Initialization...ERROR" Response
Check to see if the BIOS has ATA, SATA, Legacy setting for the HDD. Try all settings for the HDD. You'll need to have your OS CD/DVD in the optical drive as well so you can begin installation fo the OS.
If that doesn't work, Sony's tech support is pretty good if you can get them to talk to you. I've had issues w/ out of warranty laptops and PCs in the past.
Good luck.
Jul 16, 2017 | Sony RDR-HX900 DVD Recorder
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
SAMSUNG YH920GS- Error Message- device cannot initialize hdd
You are missing a critical update from Microsoft that will allow the computer to recognize this as an MTP device rather than an MSD device - this is a new problem that did not exist before.
Try a firmware upgrade, but it may not be successful since the repair was unsuccesssful.
Otherwise, get all the most recent Windows Updates from www.microsoft.com.
If none of the above work, write me back.
-Tha Mp3 Doctor
Jan 01, 2008 | Philips SA4010 MP3 Player
System initializing
Initializing H10
67
Firmware upgrade
66
What is firmware ?
Note
Open iriver plus.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
Yh925
I know your problem. Your HDD is not clipped in. Press that little square circut thing in untill you hear a click.
Oct 13, 2007 | Samsung YH-925 MP3 Player
Initial fail error
The HDD is disconnected from the player. When you open up the player just carefully push the circut board thing on the gold foil behind the hdd in untill it clicks.
Feb 17, 2007 | Samsung YH-925 MP3 Player
Try reformatting the hard drive and/or updating the firmware. If that doesn't work, then the hard drive is bad, and by extension, the whole unit is worthless. Sorry.
Apr 23, 2006 | Samsung YH-925 MP3 Player
Samsung Yepp YH-J70 Digital Media Player Logo
231 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
