Question about Compaq Presario SR1050NX (DW257A) PC Desktop
Motherbooard for Compaq Presario sr1050nx
I appear to have a bad motherboard. What is the part number of the motherboard to replace it?
  • 1 more comment
  • David Eargle Oct 16, 2006
    Where on the mobo is the board type located?
    Is it A7NBX-LA?
  • steve40040x Feb 02, 2008
    I have a Presario SR1050NX and I am looking to upgrade my processor. My understanding that depending on my socket (number??) I may be able to do this. How do I find out my socket number/model?
    Has anyone ever done this upgrade? Advise?
    TIA
    Problem Solver:
  • 7 Answers
A7 indicates that it is a K7 series - a socket 462. Socket 7's were for the old Pentium 1's and AMD K5, and K6 I,II, and III series of pre-athalon processors. Socket 7 was also the last socket to see Cyrix chips.
Posted on Nov 22, 2007
    President:
  • 2,961 Answers
Best to remove side of pc and look at the board itself, but it may be a 'socket 7 board for AMD Athlon processors, which are hard to come bye now. The next step up to your mobo would be a socket 754 type for the AMD Semperon, but it's your choice, you can go for any choice of Mobo, as long as you are buying a processor also.
Posted on Oct 15, 2006
  • andrew pester
    andrew pester Oct 16, 2006
    Yep that's the type number, which i think is a socket 7 (if you look at the processor it will probably say amd athlon) , which is old hat now, you can fit any mobo in as long as it fits and you install the right processor for the board( which both should be bought at same time at same place)
How do i replace back up batterry (cmos) in my desktop presario
The BIOS battery in most desktop motherboards is a coin size lithium battery approx. 20mm in diameter. The most common type used is a CR2030 3volt lithium battery.
To release the battery, press the metal clip to the side and the battery should pop up.
Nov 26, 2010 | Compaq Presario SR1050NX (DW257A) PC...
I can turn my computer on but monitor is blank, no mouse, no keyboard, windows vista doesnt load, just replaced the motherboard????
Yes a common situation I have see this very often, the trick is to find out the faulty component before purchasing replacement parts. Go through my guide, it deals with this matter and will get your computer going! It is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Happy testing!
damnor01
Nov 23, 2010 | Compaq Presario SR1050NX (DW257A) PC...
Compaq presario sr1050nx will not power on and the green light just flickers.
I have the same SR1050NX compaq computer with the same startup problem. I suspect this from a code seeded in the system, so performed the system recovery for several times. The problem gradually came back, automatic shutting down with loger interval. I thought the bug is in the recovery system. But the floppy drive in the cmos is disabled without choice to be activated. So, I couldn't perform FDISK at DOS mode. For this computer, I wonder anyone knows how to activate the drive for boot order besides through the setup window.
Thanks very much.
Josh
Nov 12, 2010 | Compaq Presario SR1050NX (DW257A) PC...
Will a AMD Athlon 64 processor work in a Compaq Presario SR1050NX Desktop? My old processor Died and I purchased one of these off of Ebay, now just want to make sure it will work...
No Donnie, the motherboard for the Compaq Presario SR1050NX won't support an AMD Athlon 64 processor.
The reason why is;
A) The Processor socket on the SR1050NX's motherboard is a Socket A. (Also known as Socket 462)
Hp Support > Compaq Presario SR1050NX > Specifications > Motherboard Specifications >
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00072236&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=405454
CPU = Central Processing Unit. Another term used is Microprocessor, or Processor for short.
Look to the right of the CPU heading:
Socket A (Processor socket)
This is the Socket A processor socket used on your motherboard,
http://en.wikipedia.org/wiki/Socket_A
You can click on the photo of the Socket A processor socket, to the upper Right, to enlarge.
The AMD Athlon 64 line of processors came out after the Socket A, and used the Socket 939 first.
Then on to the Socket AM2.
(Socket 940 for some models)
List of AMD Athlon 64 Microprocessors,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors
http://www.weirdstuff.com/cgi-bin/category/10201
Oct 12, 2010 | Compaq Presario SR1050NX (DW257A) PC...
My computer won't boot-I hear the fans running but nothing else. can this be fixed?
This usually means that there is a serious problem that should be looked at closely by a technician. For example, this could be related to a bad power supply, a faulty or dislodged processor, or even a motherboard failure. I could suggest checking these areas, but it is best left to a trained technician.
Mar 13, 2010 | Compaq Presario SR1050NX (DW257A) PC...
Recovery kits for Compaq Presario SR1050NX
Recover CD can be purchased from Compaq. Contact them and provide details of the model number details etc.
Jul 23, 2009 | Compaq Presario SR1050NX (DW257A) PC...
On my desk-top presario
HP/Compaq has had alot of power supply issues with this series of computers. Do you have another power supply you can try in this system? If the light is flashing rapidly, it is usually a power supply. Fairly cheap and easy to replace.
Jan 26, 2009 | Compaq Presario SR1050NX (DW257A) PC...
I cant install the ethernet driver on my compaq presario sr1050nx
go to 'support' at www.hp.com and look for dirvers for your model. There should be a driver for the 10/100 tbase ethernet device. Download and install it and reboot. Should fix the problem if the ethernet adapter is working.
Dec 12, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Replacing video card
hmmm..old card should just remove with one screw along back panel, unless it's the embedded version
go to control panel, system, device manager, and let me know what it says under audio devices.
Feb 25, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Compaq Presario SR1750NX
bad psp power supply cheak that add new one or maby ad dnew video card also could be going bad on u is it pushe dit all the way in pci slot also nicely also add alot fans if u can anyware u can open for a fan tohelp you heat issue
Jan 06, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
228 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
