My new sonicare toothbrush has gone all wobbly.... on the bottom the following numbers to help you identify the model, etc: 080416 HX6910 the vibrating pin onto which the brush attaches is no longer straight up..it bends to the side when i'm brushing...something that hadn't been happening when i first bought the brush. it's as if the bushing for this part has deteriorated...and seems to be a design flaw... spoke to my dentist, Dr. Jack Binder on w. 74th st. here in new york city; i took the brush into show him - and he said that i should write you guys; he told me that he has confidence in your ability to make it right. can you advise? Joe
  • Anonymous Jan 03, 2009
    I have a sonicare toothbrush barely a year old and the pin that holds the brush head in place no longer vibrates as it should. The battery is fine, holds a good charge but it appears the pin is bent and no longer transmits the vibration on to the brush. Any one know who can fix this ?? It has to beat buying a new brush ! Thanks. You can get me on david@osirishealth.co.nz
Your suggestion worked! I took a small common screwdriver, carefully pried on the bottom plate on each side, a little at a time, and the whole motor assembly with O-ring, came out in one piece. There it was, a small phillips screw, in this sort of universal joint assembly at the top. I tightened it up, careful, its pretty small, won't stand too much torque, but it's tight now, and I think you saved me $100 or so, mine was getting so sloppy I expected it to fall apart any day, now it feels as tight as new.
Thanks so much!
Steven Fisher
Posted on May 14, 2010
Philips Norelco is a customer of mine, I have the same toothbrush, you will need to carefully remove the batter from the bottom of the toothbrush, this isn't the easiest task, but can be done. Once you have done so, there is a small philips head screw located below the pin, just tighten that up and it will work fine. Try not to apply too much pressure when brushing using HX6000 series toothbrushes.
Posted on Jan 31, 2010
I have the same brush. I opened it up and found the cast piece that holds the retaining nut for philips head screw cracked and broken in half. This is my second toothbrush with this problem. The brush lasted less than a year (about 9-months). The design overall was good, but this one small piece that hooks the universal joint into the magnet assembly is a weak link. Since the brush has a 2-year warranty, and this brush was the replacement brush for my first failure, I will be calling them for a replacement. The original brush with the fat handle and brushes with rare earth magnets was a great brush. It didn't have Li-Ion battery, but the assembly works great. However, with the newer, sleeker design comes better battery (it is replaceable sony Li-Ion in a holder inside) but weak small piece driving the stainless head rod out the top.
Posted on Jul 25, 2010
How do I get help with my Philips Sonicare toothbrush, it runs when I am not using it, how is that possible?
There is probably no fix for it, as it is not made to be repaired; if it malfunctions, you are supposed to discard it and get a new one.
However, it is likely the problem is in the switch of the toothbrush.
It may have some foreign matter inside that is causing the contacts to close when not in use, and that its why it is turning on all by itself. If you want to try something to fix it, I would get a tank of compressed air and a blower and try blowing the air into and around the off/on switch.
It might fix it, or it might destroy it.
Aug 04, 2016 | Sonicare Philips Essence 5500 Toothbrush
Why is it making a loud noise after reacharging,never before
Are you sure the brush attachment is "tight" to the handle? Do you have a new brush to try? It should confirm handle is bad or it is the brush attachment "tightness" .
Mar 11, 2015 | Sonicare Phillips Philips Sonicare...
How do I return an item that has become defective
its 4 years old and way out of warranty. did you expect it to last forever? buy another one if you like it and dont if not. logic...
Nov 23, 2017 | Sonicare Philips EasyClean Rechargeable...
What are the best electric toothbrushes available?
The best electric toothbrushes are the Oral-b Professional Care and the Phillip Sonicare Diamond Clean. You can find more information on these electric toothbrushes on their respected websites: http://www.usa.philips.com/c/diamondclean/289711/cat/en/ and http://www.oralb.com/products/professional-care-smart-series-4000/.
Feb 04, 2013 | Health & Beauty
Philips sonicare essence 5500 doesn't stop blinking
Turn it on and put it on the charger while still on. This should turn off toothbrush. And it stopped the blinking!
Dec 11, 2011 | Sonicare Philips Essence 5500 Toothbrush
My sonicare toothbrush won't charge
The best tutorial for repairing Sonicare toothbrushes is here:
Repairing your Sonicare
The problem is either a corroded circuit board or worn-out Ni-Cad batteries. Both repair solutions require soldering, but full repair is possible.
Sep 30, 2011 | Sonicare Philips Essence 5500 Toothbrush
I'm trying to find site to register a new sonicare electric toothbrush
Hi jodnerhome,
Here is the link to register your Philips Sonicare:
http://ow.ly/6siPR
Let me know if you have any issues. Hope this helps!
Please rate this solution and comment!
Sep 12, 2011 | Philips Health & Beauty
Computers & Internet Logo
3,928 people viewed this question
David Payne
David Payne
