Question about HP Pavilion zt1135 Notebook
Power cuts out
The battery is completely dead and/or wont charge. So the battery has been removed. I think it will charge the battery if it stays on long enough. It worked fine plugged into the wall.
About 2 months ago, all of a sudden it quit. Worked with it, restarted it and it would run for 2 minutes and then completely loose power. Now it will stay running when it feels like it. But at any moment it cuts out. Some times it takes 5 - 6 times trying to start it before it decides to stay running for a bit. Sometimes when you wiggle the cord it cuts out, other times it doesnt. Could it be the power cord? Or the port that the power cord is plugged into?
  • dulcihrt Nov 14, 2008
    The battery trouble light usually didn't light up, but when it finally did, it charged for a bit and then ran for a very short time. The main trouble is not the battery.
    Has anyone had an adapter jack or power cord go bad?? Could replacing these fix this problem?
  • 128 Answers
Try to check the adapter jack with a multitester and see if there is any voltage (take note of the polarity = red test prod goes to the inner part of the jack and the black test prod goes to the outer part) set your multimeter to 12v dc. then try to move the jack with the test prod connected in a swinging motion and see if the voltage drops and comes up. if it does then you have a defective jack.
Posted on Nov 14, 2008
  • 128 Answers
Whenever you plug the adapter to your laptop, there is a small pilot light which lights up. if it doesn't light up that means your adapter is not charging your battery. if it does, then maybe you should change your battery. just a little tip : it would harm your pc if it often goes off unexpectedly or improperly shuts down.
Posted on Nov 07, 2008
  • cpenny29 Nov 14, 2008
    correction:
    sorry, but pls set the multimeter to 50v dc instead of 12v dc
2004 polaris ranger battery not staying charged when operating but when engine is off battery not affected cutting out and dying what could be the problem?
battery is being drained as it operates and not taking charge
check tightness and clean both terminals and cables
how old is the battery
may have a dead cell ..wont take charge
check the charging input to the battery with a volt meter
has to be above 12 volts
if lower or equal to 12 volts ...no good
the charging stator inside the engine needs testing or repair or replace
stator is another word for an alternator or a generator
why it plays up
best guess the ATV if a 12 volts system wont run on 11 volts
Oct 13, 2016 | ATVs
Battery wont stay charged, we had the alternator pulled out and checked by a mechanic and he stated nothing wrong with alternator..its like new.. battery is brand new and drained in less than and hour. we...
That's a pretty serious short to ground.
Go back and closely look over the waterpump install and see if you pinched a wire somewhere.
It good policy to check the last thing you did just before the problem occurred.
Oct 11, 2017 | 2008 BMW 535i Sedan
Electrical problems
no power check for battery volts should be 12.6 volts if not battery dead.if battery is weak or dead have it charged.if battery can be charged have alternator checked.if alternator bad.battery wont stay charged and you will lose all electrical power.
May 29, 2013 | 2005 Chrysler Town & Country
Phone went dead. charged it. charge complete. wont
try taking battery out for 30 seconds,then put back in!?
Oct 18, 2009 | Cell Phones
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
Sansa wont cut on when i press the power button,
That could be for a large number of problems - either internal damage from water or being dropped, a completely dead battery, a batt that wont charge, or the software is caput. The only way you can fix it is to have it repaired or refurbished. Hope you have a warranty.
Jul 21, 2009 | SanDisk Sansa e250 MP3 Player
Battery and alternator charging problem
As dumb as this may sound check the termials and if the u-shape is up then flip it over. I had the same thing happen to me on mine and now it works fine.
May 08, 2009 | 1997 Lincoln Continental
Think alternator is bad
can you get a jump start and drive the car to autozone for a charging system test ? then you are right there if they tell you the alternater is bad .
Dec 30, 2008 | 1998 Oldsmobile Aurora
Battery problem or camera problem?
A new battery should help you to solve this problem.
Aug 07, 2007 | Casio Exilim EX-Z57 Digital Camera
HP Pavilion zt1135 Notebook Logo
164 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
