Question about Microsoft Xbox 360 Console
XBOX 360 COLOR KEEPS GOING ON AND OFF
WHEN I TURN ON MY XBOX 360 SOMETIME THE COLOR FARES IN AND OUT. IF CHECK ALL THE CABLE EVEN BOUGHT A NEW AV CABLE AND IT STILL BLACK AND WHITE.I HAVE TRIED SEVERAL DIFFERENT TVS AND THEY ALL DO IT.BUT I HAVE TURNED THE TV OFF FOR A FEW SECONDS ANS THE COLOR WILL COME BACK FOR ABOUT 5 OR SEC.ANY SUGESTION
You can send your broken xbox 360 to my shop Fixit repair service and I can send you a refurbished xbox 360 system for $80 and one year warranty here is the number 206-271-0529
Posted on Nov 08, 2008
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
Ok I have a xnox 360 and when i plug the color coded cables into the color coded tv inputs i turn the channal to video 2 and i hear sound but i could not see anything? sooo what do i do?
Are you using AV or component cables?
*Solution for AV Cable*
Check to make sure the cable is fully plugged into the port. Having it even just slightly out of the socket will render no video. If this doesn't work, try plugging it into a different port on your television to make sure the port isn't bad. If you still have no video - the video part of the cable could be bad and you might need a new cable.
Also make sure that if your cable has BOTH component and AV connections available that the switch at the end of the cable near the Xbox is set to "TV" as opposed to "HDTV"
*Solution for Component Cable*
Also check to make sure that all the video connections are fully plugged in. If even one of them isn't plugged in fully, it could render no video. Also make sure that you have them properly plugged in to the right color. If you're just quickly connecting it to the back of the TV without proper lighting, it can be easy to confuse the blue and green connections.
When using component, make sure that the switch at the end of the cable near the Xbox is set to "HDTV" as opposed to "TV".
Jul 09, 2010 | Microsoft Xbox 360 Console
Not sure how to connect xbox to tv,tried the color coded adapters but picture is slanted .bought used no instruction book.
1. there are two kinds of connection
2. one u can connect through av cable which is baciscally given by xbox
2. u can also connect through hdmi cable this can be bought seperate
3. also through xbox360 vga cable (can be bought seperately) with this u can connect to lcd moniters
sometimes it is because of ur tv also, also tv dont support ntsc version xbox 360 and vise versa.
hope u got the answer
Mar 13, 2010 | Microsoft Video Game Consoles & Games
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
New xbox 360 arcade no screen or sound
to start off,what type of cable are you using??
since you've already tried using 2diff TVs,basically its with the console
try using a different AV CABLES, if it still doesnt work,try calling xbox support hotline for possible replacement of your cable or for processing a repair for the xbox if necessary..
since you just bought your console,try going back to the store where you bought it and have it replaced, because for the repalcement of the cable if you call xbox support,it will take 8-12business days for toureceive it and 2-3weeks for the turn around time of the repair for the xbox.
May 17, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
4 red lights
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Feb 17, 2008 | Microsoft Xbox 360 Console
Color problems with 360
It sounds to me like a problem within the 360s hardware itself. You could try sending it back to microsoft or like you said, going out and getting a new one.
Sep 03, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
264 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
